primary larger than flange
Old Nov 13, 2009 | 05:25 PM
thegatekeeper14's Avatar
Default primary larger than flange
well were making a set of headers, and the primaries are larger than the ports on the flange, is this bad, will there be a large amount of turblance there?
Old Nov 13, 2009 | 05:32 PM
unusual71's Avatar
Default Re: primary larger than flange
how much larger they are will make a difference, how much are we talking here?
I imagine this will only hinder the effect of the pressure waves that return to the head
Old Nov 13, 2009 | 05:44 PM
redboost10's Avatar
when we have cases like this, we will use a small diameter tube for the first 1", then step it out to the primary. not the best situation for a motor but what else are you gonna do
Old Nov 13, 2009 | 06:30 PM
TigWiz's Avatar
If the difference isn't significant it will only help minimize reversion. If fact, its preferred...
Old Nov 13, 2009 | 06:33 PM
redboost10's Avatar
these type of situations come up a lot on super stock/stock race cars where they have to use a "stock" style head, along with a tri-y step header.
Old Nov 14, 2009 | 07:29 AM
m R g S r's Avatar
better than the primary being smaller than the opening on the head flange.
Old Nov 14, 2009 | 09:32 AM
onefstek's Avatar
how much bigger? can you grind the flange to make the pipe fit in?
92cxturbo
Welding / Fabrication
Apr 18, 2011 07:03 AM
jjspec
38
Dec 29, 2009 04:42 PM
BEEYOND
Jan 26, 2006 12:45 AM
ExploitedRacing-HR
Oct 11, 2005 10:12 PM
Optiks.
Nov 27, 2003 12:29 PM
