Painting on a faded Carbonfiber wing???
Old Nov 13, 2009 | 04:34 PM
EG-SIXV-TEC's Avatar
Post Painting on a faded Carbonfiber wing???
Can you repaint a carbonfiber duckbill wing? My CF wing's clearcoat is pealing off and i want to know how to prep it, How??
what grid, sandpaper etc. I want to apply clearcoat on it, but idk how to prep carbonfiber
I also thinking of puttin clearcoat mixed with flakes ill post if finished??
but i dont know if theres a special way to prep CF????
Old Nov 13, 2009 | 04:42 PM
prelude1897's Avatar
Default Re: Painting on a faded Carbonfiber wing???
yes you can paint on your CF wing. What I would do is wet sand with 600 grit, clean it with wax & grease remover, then paint it or simply reclear it..
Old Nov 13, 2009 | 04:51 PM
Post Re: Painting on a faded Carbonfiber wing???
What brand of wax and Grease remover do you use???
Old Nov 13, 2009 | 07:17 PM
I just get the cheap stuff from Sherwin Williams or even Auto Zone. It all pretty much works the same with any brand that you get
Old Nov 20, 2009 | 01:13 PM
Cincitycustoms's Avatar
prelude1987 has it right, sand it down good, try not to get into the cf though, then shoot a few coats of catalized clear on it, wetsand and buff it, and your good to go! If you need any help pm me, Ive done this many times, and I think Ive got a step by step with photos of it.
Old Nov 28, 2009 | 12:28 PM
Hi im just wondering i finished preping and painting,
how do i finish it the clear coat is painted on and i got several runs of clearcoat onit.
what steps do i use or pics???
Old Nov 28, 2009 | 05:34 PM
FearTheH's Avatar
Use a block sander with 1000grit wet, wet block sand the runs until the surface is even. Then wet sand the whole thing with 1500 grit, and step up to 2000grit just be careful and make sure u don't sand through the clear. After wet sanding use buffing compound and a buffer at low speed being careful not to burn through the clear, after buffed, buff again using a finishing compound such as 3M machine glaze and it'll look like glass! Good luck! Hope this helps! And post some pics
EG-SIXV-TEC
Paint and Body
Nov 25, 2009 04:32 PM
Hondaciv95VX
Jan 26, 2006 01:26 PM
Hondaciv95VX
Jan 11, 2006 08:04 AM
whitetyper
Aug 17, 2004 08:19 PM
OneThirtyEight
Oct 27, 2001 10:33 PM
