Need Help! Blowing Fuse 15 on a 97 EX
Old Nov 13, 2009 | 12:15 PM
craigers2k's Avatar
New User
Default Need Help! Blowing Fuse 15 on a 97 EX
I have a 1997 Civic EX coupe. I am having problems with fuse 15. I am well aware of the TSB about wires rubbing on the intake manifold bracket causing them to short. Here's a bit of a recap of what I've done:
After first having the problem, I looked at the wires above the bracket to find no damaged wires. I wrapped a few of them in electrical tape, did not solve the problem.
Later I took a closer look at all the wires, no damaged ones found. I wrapped the everything that I could find in tape. still did not solve the problem.
Today, I tried again verifying the wires under above the bracket, and by re-wrapping all of the major connection points around the bracket. No luck. I left the bracket off, no luck, kept blowing the fuse. I unplugged my oxygen sensor, still blew the fuse. Unplugged the speed sensor, and still blew the fuse.
It takes about a quarter mile for the fuse to blow when I put a new one in. Any other suggestions on what the problem could be??
Old Nov 13, 2009 | 02:26 PM
Former User's Avatar
Default Re: Need Help! Blowing Fuse 15 on a 97 EX
If you install a new fuse 15, reset the ECU to clear CEL codes, and drive the car, does the CEL come on before fuse 15 blows? If so, what is the code?
Old Nov 13, 2009 | 07:18 PM
craigers2k's Avatar
New User
No, the fuse pops and the speedo starts dancing, followed by the CEL a few seconds later.
Old Nov 15, 2009 | 05:29 PM
craigers2k's Avatar
New User
Can anyone tell me exactly what is connected to that fuse electrically?
Old Nov 15, 2009 | 08:17 PM
What CEL codes do you retrieve?
mtownsi
Sep 23, 2012 03:48 PM
John Hencock
May 31, 2011 06:21 PM
biev
Jan 15, 2009 09:00 PM
z6
Apr 29, 2004 12:34 PM
Turbolude
Oct 17, 2001 08:12 PM
