Upgrading ingition opinions
Old Nov 13, 2009 | 10:46 AM
str8JDMteggy's Avatar
Default Upgrading ingition opinions
Im doing some mods this winter and its come time where i need to upgrade my ignition. Right now im running stock ignition and the car is tuned on Neptune. The car made 540 wheel last spring and started to run out of fuel. Im going with an inline bosch 044, different cams and bigger injectors, trying to make 600+whp. What is the best option to upgrade my ignition while still using neptune.
Old Nov 13, 2009 | 02:48 PM
runsfromdacops's Avatar
Default Re: Upgrading ingition opinions
No. Need to upgrade from the stock stuff for 600+ around 700+ you will need to but not for 600
Old Nov 13, 2009 | 03:14 PM
vietjdmboi's Avatar
even tho you are fine with your ign system. you can always upgrade using an M&W pro 10 box with a crane cams ps92 coil. check out www.t1raceparts.com
tony has a complete kit for sale with the wiring harness. you will be able to use this with neptune, hondata, aem etc etc.
JBLAZE622
Jan 5, 2009 09:16 AM
Jhill_9202
Oct 24, 2005 07:52 AM
GSRacer1
Nov 8, 2002 10:05 PM
Kellindal
Dec 19, 2001 11:52 PM
