dpfi to obd1 help
Old Nov 13, 2009 | 04:32 AM
thundernutz's Avatar
Default dpfi to obd1 help
i am running obd1 injectors and i have a resistor box the car wont start so i took the 4 black wires on the resistor box and tied them together with the red wire is that all i need to do to bypass the resistor box car wont keep running turns over then dies any ideas thx
Old Nov 13, 2009 | 07:12 AM
D16SiHatch's Avatar
Default Re: dpfi to obd1 help
sounds like you've got it right. remove the resistor box and solder the 5 wires together.
Old Nov 13, 2009 | 07:28 AM
jlicrx's Avatar
the injector resistor box should have a yellow with black stripe wire and 4 red with black stripe wires coming out of it - cut all of the wires - take the 4 yellow with black stripe wires that come from each OBD1 injector and connect all of them to the yellow with black stripe wire that went to the resistor box - if the car was converted from DPFI to MPFI, it should already have 2 yellow/black wires connected to the yellow/black from the resistor box, in which case you will essentially be connecting 6 yellow/black wires together
Dunc
Oct 2, 2005 02:12 PM
TYPErCRX
Feb 28, 2005 03:27 AM
DOHClessEF-9
Feb 5, 2005 04:35 PM
valentino2k3
Dec 7, 2004 10:06 PM
shivern
Nov 28, 2004 08:51 PM
