help used search Installing eg visors
you pull the weather stripping that goes on the out side of the door that the window rolls up to... then put the visors in that re install the weather stripping... it's really easy... if you look at you door i'm pretty sure you can figure it out... it takes ten minutes.. good luck
EG_1988
Apr 5, 2009 10:15 AM
