ITR axle back on EM1
Old Nov 12, 2009 | 05:29 PM
raphael's Avatar
Default ITR axle back on EM1
Stock exhaust on there now. I wonder how much work will it take to put it on. Also is it really worth it?
My idea is to swap a 97 b18c5 and throw on a 98 spec JDM header with stock cat and some custom piping into the USDM ITR axle back. Anyone have a better idea on a clean and simple yet effective exhaust setup with this swap. I'd rather not go loud or expensive please. No track time just smooth driving with a little heavy foot here and there.
Old Nov 12, 2009 | 07:24 PM
raphael's Avatar
Default Re: ITR axle back on EM1
Wow made it to thee second page in less than an hour
Old Nov 13, 2009 | 01:02 PM
raphael's Avatar
Woope no response
Old Nov 13, 2009 | 01:11 PM
burningrex's Avatar
you are going to have to cut the piping off the axle back and have them redo it or it won't clear the lca's
Old Nov 13, 2009 | 01:12 PM
gsrpedro's Avatar
yea i think its worth it
Old Nov 13, 2009 | 01:19 PM
raphael's Avatar
will the collector on the header fit the stock cat?
Old Nov 13, 2009 | 01:49 PM
vrquick's Avatar
I just put stock ITR exhaust on my EM1 last month. Bought the car with a really loud exhaust and my friend gave me the ITR exhaust for free. It bolts up no problem. You have to remove the center heat shield or you can dent it a little cause it rubs on the bolt that holds the heat shield. Next it just barley rubs the corner of the gas tank. I just beat a flat spot on the exhaust so it doesn't rub. Last the exhaust tip is about 6 inches short. I carefully cut off the polished tip and not the entire tip coming out of the muffler and bolted on a hookers header 3" slash cut exhaust tip. Now I have a stainless 2.5" exhaust that looks and sounds stock.
Old Nov 13, 2009 | 04:16 PM
raphael's Avatar
so since the muffler tip was 3 inches short you cut off the tip and left just enough pipe on the muffler to weld a 3 inches of pipe to the SS tip? i cant really make out what you wrote there. also what about the hangers?
i really wonder how free flowing the itr muffler is. i wonder what oem honda muffler is a better option if there is
Old Nov 13, 2009 | 04:18 PM
speedooo's Avatar
a 4dr itr axle back will fit like stock
Old Nov 13, 2009 | 04:22 PM
raphael's Avatar
yeah but where im a going to find that around my way. gatta love those 4-door itr's they are uber rare
Old Nov 13, 2009 | 08:57 PM
speedooo's Avatar
http://jdmcoupecouncil.com/forum/showthread.php?t=7718
Old Nov 13, 2009 | 09:10 PM
k20delslo's Avatar
No Sales Forums
raphael can you just start a build thread please.
Old Nov 14, 2009 | 05:43 PM
vrquick's Avatar
The exhaust is about 6 inches short. There is a pipe that comes out of the muffler and then the polished tip is welded to that. I cut the weld on the polished tip and removed it so it was just the 2.25" pipe coming out of the muffler. I then got a 3" diameter by 8" long exhaust tip and bolted it to the 2.25" pipe coming out of the muffler.
Old Nov 15, 2009 | 05:01 PM
raphael's Avatar
so how much better did it perform with the new exhaust?
Old Nov 15, 2009 | 05:15 PM
gtz's Avatar
gtz
i can confirm that 4 door ITR axle back will fit like stock on an ej8/em1
Clears my Blox LCAs and sway bar.
Bolts right up to dc2 ITR exhaust, including ITR cat, just had to have the hangers modified.
Your stock cat will not bolt up to the ITR 4-1 header.
EPR145
Southeast (Sales)
Sep 16, 2009 12:37 PM
frstwhtgsr2000
Jan 11, 2007 08:52 PM
91ls-v
Northern California (Sales)
Dec 15, 2005 10:51 PM
JoNNiE
Jan 18, 2005 10:17 AM
