**Help** OBD2-A to OBD2-B??
Old Nov 12, 2009 | 05:01 PM
T3X's Avatar
T3X
Default **Help** OBD2-A to OBD2-B??
I have a 98 civic and i am attempting to swap it with b16a2. i need to know if i can use the OBD2-b harness on my car.
and also if some one could tell me what these 2 wires are for on the drivers side of the harness because they are not on my OBD2-b harness?
Sorry for the HUGE pictures
this is off my OBD2-a harness (the blue one is blue with a brown stripe)
this is the OBD2-b harness missing those 2 wires
Help me out please
Old Nov 12, 2009 | 08:27 PM
-__-'s Avatar
Default Re: **Help** OBD2-A to OBD2-B??
what ECU are u using? if ur using the stock Si ECU, use the OBD2-B harness cuz if u use the OBD2-A harness, u will need a jumper harness.
Old Nov 13, 2009 | 07:06 AM
xcivicboy86x's Avatar
I did this swap into my 1997 EX sedan and every thing is plug and play minus the ecu, but i got mine BAR'd.. if you arent trying to BAR your car then get a p28 or something obd1 with a jumper or if you want a plug and play option you can find a JDM P2T which has the obd2-a plugs or i think it is a P30 but from the 96-97 del sol SI goold luck its rare and expensive.. but the usdm P2T has od2-b plugs which requires a jumper which i had to use for mine... and i believe all civics in 98 came with the FTP sensor so you wont have to worry about that engine code like i do if you use the USDM P2T.. also what base model do you have?? you may need to add pins for some of the sensors...
Old Nov 13, 2009 | 04:44 PM
T3X's Avatar
T3X
i have an EX, and i know most of what you said, but here's a question. if i was to use the obd2b harness would i have to worry about anything? cause then the P2T would just plug right in, the only thing i would be worried about is the 2 wires that i pointed out in the pictures, the obd2b harness doesn't have those :/ are they important or just some D series **** i ain't gotta worry bout????
Old Nov 13, 2009 | 05:31 PM
geneeunit's Avatar
you need a 99-00 underdash harness if you plan on using the harness from the b16a2.. if you use your factory harness and add wires and what not, you can just re-pin your OBD2a plugs to work with the OBD2b P2T ecu, or buy a conversion harness.
OBD2a:http://technet.ff-squad.com/wiring.obd2a.htm
OBD2b:http://technet.ff-squad.com/wiring.obd2b.htm
Old Nov 13, 2009 | 05:38 PM
T3X's Avatar
T3X
so basically i gotta pull the dash and swap the whole harness over if i want to use the obd2b ****?
Old Nov 13, 2009 | 05:53 PM
geneeunit's Avatar
yup..
Old Nov 13, 2009 | 06:14 PM
T3X's Avatar
T3X
oh well, i was trying to prevent that but i guess it will give me a reason to tuck it. lol thanks for the help man
Old Nov 13, 2009 | 06:21 PM
geneeunit's Avatar
yeah, no problem. good luck and if you need any help, dont be afraid to shoot me a pm.
D_koschak
Jan 21, 2011 05:46 PM
B18c1turboedEK
Jan 31, 2010 03:15 PM
nello a.
Dec 24, 2008 12:20 AM
oneforce
Apr 24, 2006 10:21 AM
