96 VTEC Auto Speedo not working
Old Nov 12, 2009 | 09:52 AM
craiger28's Avatar
Default 96 VTEC Auto Speedo not working
Speedo is not working. RPM, Temp and Gas all working on cluster. CEL on with VSS code. Replaced VSS and still the same. Any suggestions.
Old Nov 16, 2009 | 01:21 PM
craiger28's Avatar
Default Re: 96 VTEC Auto Speedo not working
BUMP.
OK so more information on this issue: Took the VSS out of the car and check the volts by waiving a piece of metal across the magnet on the vss and got some readings. Put it back in the car and turned the wheel and got some voltage readings. The cruise control button lights up green when I press it on, but it doesn't light up on the dash or work while going down the road. I looked at all the wiring I could see and saw no bare or wearing at all to any wires. I really need some suggestions on this issue. HELP!
Old Nov 16, 2009 | 01:44 PM
P_Adams's Avatar
Clear the code? you didn't mention.
It's either the Vss (again) or the wiring to it (if what you're relating is accurate).
P
Old Nov 17, 2009 | 09:10 AM
craiger28's Avatar
Hello P. Adams, nice to hear from you again. I did clear the code because I disconnected the battery to install a good alternator, the old was only putting out 11.97 volts. How could it be the VSS as I did all the appropriate tests? checked all the wiring closely too.
Strange thing, now I can't get the CEL to come on even when I first turn the key on and it usually clicks. Maybe this is a computer problem. Whats your thoughts????
Old Nov 18, 2009 | 12:45 PM
craiger28's Avatar
BUMP. Come on guys, help me out. Is this the computer???
Old Nov 18, 2009 | 02:48 PM
craiger28's Avatar
OK I figured one part out, the CEL was blown. I checked it with another bulb and now I don't have a working bulb for the brights.
BUT, I have hooked up the jumper wire on the blue connector and the light just stays on and does not blink. WHY?
Also still need to know why the speedo doesn't work?
Old Nov 18, 2009 | 07:03 PM
AWOC's Avatar
The sending unit that is located on top of the transmission is bad. It is common from time to time. I had to replace one on a 90 accord recently. Replace that and your speedo should be fine.
Old Nov 19, 2009 | 06:28 AM
craiger28's Avatar
Well I will try this out. When you state sending unit, could you be a little more specific. I am pretty sure the part you are speaking of but want to be sure.
Old Nov 19, 2009 | 07:43 AM
craiger28's Avatar
OK, I replaced the solenoid on top of the tranny, no dice! Also, I switched out the cluster with another 96 accord EX Vtec that I have and know is working and still no dice. I need some help on this issue. Come on guys?????
Old Nov 24, 2009 | 07:26 PM
craiger28's Avatar
Bump, still waiting for help. P. Adams, are you still out there???
Old Nov 25, 2009 | 04:47 AM
nus_dogg's Avatar
I think he mentioned that on his first or second post that its been replaced.
Old Nov 26, 2009 | 07:36 AM
craiger28's Avatar
nus dogg, what are you talking about? What's been replaced?
Old Nov 29, 2009 | 05:54 PM
craiger28's Avatar
Still waiting for some help????
Old Dec 3, 2009 | 01:08 PM
craiger28's Avatar
I switched out the ECM/PCM from an identical 96 accord Vtec Auto that I have with the same part numbers after getting some advice from a honda mechanic. It still does the same thing... no speedo or odometer movement and CEL P0501. I believe I have a bad wire somewhere just don't know where???? HELP!!!!
Old Dec 5, 2009 | 07:14 AM
craiger28's Avatar
checked all wiring under the intake manifold and found nothing exposed or rubbing against metal. All the connectors on this Accord is above the strut towers on both sides. All of them look good with no contamination. What else could this problem be????
Old Dec 8, 2009 | 04:56 PM
craiger28's Avatar
Cleaned all grounds. one on the transmission and the other on the body of car. Didn't work.
Old Dec 8, 2009 | 09:48 PM
accord2nrz's Avatar
Did you replace the VSS?
Steven Hamke
Jun 3, 2019 05:08 PM
robomc13
Honda Civic (2001 - 2005)
May 30, 2013 11:20 AM
thecorey
Oct 13, 2008 08:06 PM
sireg6
Sep 26, 2006 01:38 PM
dthug
Aug 17, 2006 11:29 AM
