s2p3 camshafts
Old Nov 11, 2009 | 12:11 PM
h22 kid's Avatar
Default s2p3 camshafts
anyone running these on there cars? i need to know if they are safe to use as a daily and i heard that when you install these your always in vtec is this true?
Old Nov 11, 2009 | 12:27 PM
NirVTEC's Avatar
Default Re: s2p3 camshafts
If you have a true need for S2P3s, I will have to guess your setup is NOT good for daily driving.....13:1cr?
There are a handful of people running them, most notibly Natalie from Blacktrax. She was one of the original testers.
As far as I know, they are NOT VTEC killers.
Old Nov 11, 2009 | 12:38 PM
h22 civic's Avatar
no they aint,, expect to pay around 2500 bux for a descent set of vtec killers
Old Nov 11, 2009 | 01:29 PM
NirVTEC's Avatar
I'd be curious to see what his setup is. Most people that ASK about P3s barely have the setup to justify Pro2s.
Old Nov 11, 2009 | 03:57 PM
h22 kid's Avatar
i have a stroker kit 2.2 to 2.5l and compression at 12:5:1 going to p&p... sleeved block and have all the valvetrain... everything is there built to run it just before i do it was just making sure if i could DD it.
Old Nov 12, 2009 | 07:08 PM
h22 kid's Avatar
no help?
Old Nov 12, 2009 | 08:54 PM
Mike95lude's Avatar
If this is your setup, then most certainly it would benefit from Pro3's. There is no reason you can't daily drive a setup like that. Why do you think you could not?
Old Nov 12, 2009 | 11:16 PM
h22 kid's Avatar
yes it is my setup and i thought i couldnt because someone said that when you put s2p3's in they act as a vtec killer and your always in vtec was trying to see if thats true
Old Nov 13, 2009 | 06:47 AM
Mike95lude's Avatar
Nope, the Pro3's just have a more aggressive non-vtec profile than most other "off the shelf" cams, but you can tune the idle to be smooth just like stock for the most part.
Old Nov 13, 2009 | 09:07 AM
NirVTEC's Avatar
Sounds like a great setup for the Pro3s.
What crank is that? Crower?
Old Nov 13, 2009 | 10:33 AM
h22 kid's Avatar
yes correct... the torque it is amazing! i got a **** tune just enough to able to drive the car around and was at 201 tq and 200 hp
Old Nov 13, 2009 | 12:16 PM
NirVTEC's Avatar
What cams are you running right now?
200whp/201wtq? Weird.......
Old Nov 13, 2009 | 01:46 PM
h22 kid's Avatar
s2p2's.. it was only tuned to make the car run... i was supposed to go back to get it tuned after i fixed some things that were in need of fixing.. i fixed them and then a cam gear slipped and blew my pistons and broke my valves... so im just refinishing that up to get started all over again. the tuner wasnt at fault because they never touched the gears to make adjusments. just my own fault not knowing that when you put the gears on the cams your suppose to torque them down before using them..
Old Nov 13, 2009 | 01:51 PM
NirVTEC's Avatar
Ouch....
Old Nov 13, 2009 | 04:03 PM
h22 kid's Avatar
yeah i know
Old Nov 14, 2009 | 06:32 AM
NirVTEC's Avatar
yeah i know
Please keep us posted on the build. I would love to see how the setup turns out when its healthy.
I would still contact Nat from Blacktrax...
What are you using for header/intake manifold?
Have you considered E85? Ohhh.....wait, Cali FTL on that.
Old Nov 14, 2009 | 06:57 AM
h22 civic's Avatar
nice build ....pro 3s will work for ya .....that setup should make nice power.prob low 300s..i know theirs a crane/ferrea all motor roller setup floating around here for cheap that would work sweet also... ;] ....lol ...good luck!
Old Nov 14, 2009 | 07:56 PM
h22 kid's Avatar
thanks everyone.. i will keep up what i do on this particular thread.. if anyone would like to know or see how my motor came out after the accident i will post up pics.. i know some people here have seen it. lmk
Old Nov 15, 2009 | 12:48 PM
q16racer's Avatar
i hope you know how to degree cams. thats why your internals became friends in the first place. Going to the Pro3 means taking steps in even greater excess to ensure the correct clearances. The Pro cams are NOT drop in cams.
________
Girlfriend pictures
Old Nov 15, 2009 | 01:33 PM
h22 kid's Avatar
yeah i know that. i had a machine shop build my motor and he did all the arrangements... just the cam gears were not bolted down and they slipped causing the internals to meet
94hatchvx
Oct 22, 2010 04:19 AM
SIReg9
19
Mar 9, 2004 05:00 PM
7thGear
Dec 10, 2003 11:19 AM
drvfast
Sep 15, 2002 02:18 PM
