Oil temp, Oil pressure and water temp gauges...
I have a 98 teg LS VTEC... looking to put some gauges on it.
Oil temp - I have a moroso oil pan... with a temp plug...
Oil pressure - i guess ill go with one of those oil filter doughnuts, not sure what brand to go with...
Water temp - I have no idea where to run that off of
what is every part I need? I am going with autometer gauges.
HELP PLEASE ! thanks.
I'm running my oil temp and oil pressure off of a 'sandwich adapter' that threads in behind the block where the filter threads onto.
as for the temp sensor, you'll also need an adapter that taps into the upper rad hose to accept your temp sensor.
that's how i ran my gauges.
just to help you, here's a pic of my sandwich adapter:
and here's a pic of my temp sensor adaptor (yes, you will have to cut your hose):
Last edited by Mashimaro; Nov 11, 2009 at 11:18 AM. Reason: added pics for reference
for the oil pressure...i came off the back of my block with a "T" fitting...one of which i ran my aftermarket sender in one side...and my oem one for the light on the dash and ecu on the other side.....as for my water temp i took the oem one out of the side of the head and put it in there and just discontinued the oem one...
i bought my stuff from my local shops, but i'm sure you can find it cheaper online in the US.
my gauges came with all the sensors. if you buy used, sometimes you might not get them but it's probably better to get new ones anyways if you're going used (sensors).
mr abstract
Jan 23, 2007 02:00 PM
CRX Lee
60
Jul 22, 2005 09:13 PM
