Alignment results, how bad before/after?
01 integra GSR, wheel was pulling super hard to the left, and CRAZY wear on the inside of tires.
results
so how bad was it before, and are the new numbers good?
The car drives awesome now. im so happy
results
The front toe out was pretty bad. It was probably pulling alot side to side and felt jittery. Now its close to zero so the tires wont wear and it should feel more stable. You also have -2.5 camber which will be good for cornering. The results are good. But when I get my car done its usually toe at 0.00 or -0.01. lol im picky.
toe is fine, camber is fine.
i prefer a bit of toe out up front, but thats ok. toe in helps for highway stability.
btw, your toe was absolutely horrible before. it would have resulted in tire wear.
93accordf22a
Jan 20, 2009 08:26 AM
EJ1 wilcox
Suspension & Brakes
36
Apr 27, 2006 08:16 PM
stiness101
Jan 13, 2006 05:51 PM
