NEED HELP!! crank no start
Old Nov 11, 2009 | 10:30 AM
wolf95's Avatar
Default NEED HELP!! crank no start
I have a 95 del sol si. It started fine yesterday but wouldnt start this morning. I havent done anything to it since last night. I thought it would be the battery but i ran it to autozone and they said its fine. We tried jumping it and push starting it. It will crank but not turn over. NEED HELP!!
Old Nov 11, 2009 | 10:52 AM
asphaltrocket's Avatar
New User
Default Re: NEED HELP!! crank no start
did ya check for spark, check for fuel. thats usually were you start, honda the best car on the road, probably your distributor
Old Nov 11, 2009 | 11:02 AM
wolf95's Avatar
I am not getting spark
Old Nov 11, 2009 | 12:15 PM
wolf95's Avatar
screw it. its going to a shop
Old Nov 12, 2009 | 05:06 PM
wolf95's Avatar
ended up being a fried dizzy. Do these just crap out like this or could something else cause this?
Old Nov 12, 2009 | 05:43 PM
92shade's Avatar
they do fry out alot, atleast it has happened to me twice in about a year
Old Nov 13, 2009 | 12:46 PM
wolf95's Avatar
ok heres the problem and i'm trying to contact any mechanics who could help me with my
problem.
My car randomly wouldnt start the other day. We checked the battery and it was
good.
We towed it to the shop and they said it was the distributor because it wasnt getting spark.
My friend replaced the distributor because I had him buy the $165 dizzy at autozone instead of the $350 one at the shop. It still wont start.
The mechanic at the shop said he smelt something burning and that the dizzy had burnt out, either by them doing something or the constant cranking.
the wires still arent getting spark. He is checking the wiring and fuses and so far everything is fine.
The dizzy cap and wires are brand new and the plugs are a lil black but still fairly new. It ran perfectly fine the day before. i'm SO lost to what it could be...
and they wanna charge me $75 bucks for NOT telling me what the problem is. any help would be appreciated.
Old Nov 13, 2009 | 02:12 PM
Former User's Avatar
Have you checked whether the timing belt snapped?
Are the coil and igniter unit new? Have you tested them? Does the dizzy get battery voltage with the key in ON(II)?
Any CEL codes?
Old Nov 13, 2009 | 02:25 PM
wolf95's Avatar
Timing belt is perfect. the cap and wires are brand new. The dizzy will spin when u crank it. and it's not throwing any codes but a while back when i checked for it, it was showing a VSS sensor code but i believe that was cuz my vss is wired weird.
Old Nov 13, 2009 | 02:27 PM
Have you tested the coil and igniter unit inside the distributor? Does the dizzy get battery voltage?
Old Nov 13, 2009 | 02:29 PM
wolf95's Avatar
That i'm not sure cuz i'm outta town. its a brand new dizzy from autozone
Old Nov 13, 2009 | 04:58 PM
shawn_crx's Avatar
when i swapped out my dizzy, it didn't want to start, then I ground one of the spark. Car start right up. Check for ground?
also pull all your spark plugs and dry or clean them with a towel/rag.
Old Nov 13, 2009 | 07:51 PM
wolf95's Avatar
Well we tested to see if it had spark in the wires and it didnt.
Old Nov 15, 2009 | 09:30 AM
wolf95's Avatar
ok, we replaced everything from the distributor to the spark plugs and its still not firing and has an ignition CEL code. what else could make it not have spark?
Old Nov 16, 2009 | 09:03 AM
Again, does the dizzy get battery voltage on the Blk/Yel wire?
Old Nov 16, 2009 | 08:24 PM
wolf95's Avatar
ended up being a defective dizzy. exchanged it and she started right up. thanks for all the help!
lacking vtec
Jun 23, 2006 07:47 AM
13BT
Jul 26, 2005 06:10 AM
asiansgoweeee
12
Jan 16, 2005 11:03 PM
H23ludedude
Apr 24, 2003 08:50 AM
HYBRIDGSiR
Nov 23, 2001 07:32 AM
