RC injectors question
Ok, I know a million people post about the O ring but my injectors are installed. The problem I am having is that the clips dont have enough room to clip on.
My setup is a
OBD 1 injectors
OBD 1 fuel rail
RC 310 saturated injectors
The clips dont seem to want to seat down completely over the clip. They look like OBD 1 clips and the person I got them from said they work with OBD 1 clips. But the two corner clips are getting blocked from the rail where it squares off. And I dont seem to be able to hook the clips down all the way. Is it possible to have the top of the injector to far in the rail? Any suggestion would be appreciated. I just switched my clips from OBD 0 to OBD 1 during the conversion. If anyone has an idea please let me know.
Thanks,
Ryan
My setup is a
OBD 1 injectors
OBD 1 fuel rail
Thanks,
Ryan
Look here,
https://honda-tech.com/forums/tech-misc-15/modifying-obd2-injector-clips-work-obd1-injectors-1936840/
Perhaps you have OBD2 injector harnesses and need to perform this mod.
My setup is a
OBD 1 injectors
OBD 1 fuel rail
Thanks,
Ryan
My setup is a
OBD 1 injectors
OBD 1 fuel rail
Thanks,
Ryan
Loosen the rail, and slide the injectors out slightly then plug them in first, and bolt the rail back down. If I am reading your post right, this is the same thing I ran into. I couldn't get the clips on until doing that.
Thanks guys
Ryan
SpoolnG2
May 18, 2004 12:33 PM
superduperman
Sep 13, 2003 12:37 AM
Chubz
Mar 3, 2003 07:23 AM
