B18a1 question
Old Nov 10, 2009 | 11:30 PM
Eks_86's Avatar
Icon2 B18a1 question
got a LS swap on my ef cranks but no start got spark wiring fine ....... idk need help .......
Old Nov 10, 2009 | 11:31 PM
Eks_86's Avatar
Default Re: B18a1 question
Timing is fine ???
Old Nov 10, 2009 | 11:57 PM
Eks_86's Avatar
any 1 ???
Old Nov 11, 2009 | 06:52 AM
PiKapp504's Avatar
Are you getting fuel? Is the timing right? Did it ever run in your car? A little more info would be helpful...
Old Nov 11, 2009 | 07:02 AM
System Lord's Avatar
check timing and relay need more info
Old Nov 11, 2009 | 03:34 PM
Eks_86's Avatar
ya im getitn gas i just swap it i had z6 before
Old Nov 11, 2009 | 04:30 PM
Eks_86's Avatar
im checking the timing again
Old Nov 11, 2009 | 04:32 PM
ryanevansoh's Avatar
codes?
Old Nov 11, 2009 | 04:43 PM
hondaex99's Avatar
maybe the dizzy or ecu....
Old Nov 11, 2009 | 08:40 PM
Eks_86's Avatar
got chip p28 ima change the dizzy hope it go...
Old Nov 12, 2009 | 12:43 AM
is the p28 chipped for an ls basemap and non vtec? i would suggest getting a pr4
Old Nov 12, 2009 | 06:39 AM
hondaex99's Avatar
i have a pr4 for sale $20
Old Nov 12, 2009 | 07:05 AM
jhammond_82's Avatar
Reject Papi
main relay perhaps? are you getting fuel?
Old Nov 12, 2009 | 07:54 AM
Eks_86's Avatar
Now it starts for 3 second en it dies ???
Old Nov 12, 2009 | 08:48 AM
Malgerus's Avatar
Check firing order, spark in each cylinder, etc
Old Nov 12, 2009 | 09:06 AM
Eks_86's Avatar
firing order good brand new plug en wires
Old Nov 12, 2009 | 10:52 AM
Reject Papi
main relay. if its starting for like 3 seconds and dies, change the main relay.
Old Nov 12, 2009 | 09:46 PM
Eks_86's Avatar
not the main relay change it today still doing same thing
Old Nov 12, 2009 | 10:57 PM
ninty1civic's Avatar
what'd you do differently to get it to start for 3 seconds then die? what year "ef" is it? is it a crx hf? is it a civic si? is it a crx dx? etc. etc.
Old Nov 12, 2009 | 11:06 PM
Eks_86's Avatar
91 sedan dx converted to OBD1
Old Nov 14, 2009 | 07:55 PM
Eks_86's Avatar
bump up any 1
Old Nov 14, 2009 | 09:36 PM
codes????
Old Nov 14, 2009 | 10:08 PM
placid888's Avatar
which obd integra you got??? b18a or b18b??
Old Nov 14, 2009 | 10:14 PM
haynes says 1. loose or faulty eletrical components at distributor, coil or alternator.. 2. insufficient fuel reach the injectors.. 3. vacuum leak at the gasket between intake manifold/plenum and throttle body..
Old Nov 15, 2009 | 12:17 AM
Eks_86's Avatar
Tnx alot ima check
