car misfires and bogs with s300
heres the deal at idle the car misfires not crazy but i can tell my question to that one is do i have to run special spark plugs wit s300.. and second wen i am driving normal (slow) the car bogs around 2rpms like as if i shut off the car but if i let go of the gas and tap it again it picks right back up and this happens everytime i shift into second as soon as i let out the clutch is bogs and picks right up.. could this be the tune or a ignition problem?
if your having problems with the s300 i recommend saving your datalogs and calibration and posting them up to the hondata/smanager forum where there is much more experience IMO on the hondata forums, spunkster and hondata definitely know more about s300 than any other joe shmo on this forum which could possibly start to lead you in the wrong direction. So post your question there, with your datalog and calibration files and you'll get it solved..
Sounds like you need a tune really bad if you didn't know there are files with pre set calibrations for s300 you could use that Hondata has written into the s300. Hondata has also allowed other tuners to place calibrations on there website under there forum section
superfuji57
Aug 8, 2004 07:44 PM
