Tie Rod Bolt Spins!
Old Nov 10, 2009 | 10:23 AM
LOC714's Avatar
Icon6 Tie Rod Bolt Spins!
hi guys...I am having trouble tightening the tie rod nut (crown nut) to the tie rod bolt. It came up halfway using a impact gun, now it just spins with the nut as I tighten it. Any suggestions of trouble shooting this without buying a new one? -Any advice would be much appreciated!
Old Nov 10, 2009 | 10:28 AM
Simkin314's Avatar
Default Re: Tie Rod Bolt Spins!
Commonly the tie rod bolt is a tapered stud (which fits the appropriate mating taper on your vehicle). If you hold your tie rod down with enough strength, maybe you can keep it from spinning... it really depends on how badly the nut is secured to the threads.
I had to all-out replace my tie rod due to this issue.
Old Nov 10, 2009 | 11:38 AM
the boogler's Avatar
make a small slit on the bottom of the nut, wide enough to fit a flat head screwdriver. now hold a screw driver in it and have someobdy turn the nut with a wrench.
Old Nov 10, 2009 | 12:05 PM
AznBlueBoy's Avatar
I had to replace mine too when this happened.
Old Nov 10, 2009 | 12:14 PM
thumper64's Avatar
I thought when these sorts of joints started spinning, you were supposed to replace them. Just buy Moog ones, they have a lifetime warranty.
Old Nov 10, 2009 | 02:47 PM
92civlude's Avatar
Try squeezing the tie rod to the knuckle with some big channellocks. Zap the nut off with a gun.
Old Nov 10, 2009 | 06:30 PM
jonbar87's Avatar
what he said^ take a pair of vice grips or a c clamp or something of that sort and squeeze the bolt further into the hole..that's how I dealt with mine.
Old Nov 11, 2009 | 03:44 PM
LOC714's Avatar
thanks everyone...i tired putting all sorts of pressure on this **** but it still spins. looks like i gotta get a new one.
Old Nov 11, 2009 | 05:29 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
not enough pressure then. use your jack and jack up on the lower arm that should give you enough pressure to keep it from spinning.
Old Nov 11, 2009 | 06:16 PM
92civlude's Avatar
I wonder if the threads are destroyed.
Old Nov 11, 2009 | 08:31 PM
terror_storm's Avatar
The taper keeps the stud from turning.
If the taper is dirty, it will spin easily.
Clean the stud and the hole it goes into with brake parts cleaner.
Allow time for cleaner to evaporate.
Insert the stud into the hole.
Apply some force to get the taper to 'grab' while you slowly turn the nut with a wrench or preferably a ratchet.
Do not use air, it will only break the taper friction.
Old Nov 12, 2009 | 08:25 PM
autoluder's Avatar
my rear lower ball joints were spinning, but after i caught them on a angle with the electrical impact wrench the nuts caught and started turning. you might want to try that, it worked for me..
Old Nov 12, 2009 | 09:17 PM
try what i said itll work 100%
Old Nov 13, 2009 | 02:52 AM
H24Turbo's Avatar
get a pry bar, and pry down on the top of the tie rod end. then while still prying (pushing down) take your wrench and take the nut off. I've done this many of times it'll work.
Old Nov 14, 2009 | 10:46 PM
fastlane2's Avatar
I'd use a tap and a die to clean the bolt and nut. Then you can clean it and put never siege on it.
Old Nov 14, 2009 | 11:30 PM
Gofmf's Avatar
same way i do it, if it doesn't work have one of your heavier friends put some weight on the tie rod while you turn the nut
zccr-xsi
Sep 25, 2005 06:24 AM
importdude2000
May 8, 2005 04:01 PM
RCautoworks
Jun 28, 2004 07:10 AM
RCautoworks
Jun 22, 2004 09:02 PM
Lei Siew Long
Dec 29, 2002 12:54 PM
