hard start, wont rev past 3500, code 13
ok so i finally got my crx up and running and it seems to run pretty decent just a few problems. its hard to start unless its been running for a few minutes and still takes a few seconds to start up. if i spray ether in before starting up after a day or so it fires right up. ive changed out iat, tw, tps, checked numerous things. cant figure it out. also wont rev over 3500rpm. ive also swapped ecus and same. throwing code 13 which is pa sensor. whats the symptoms of this sensor bad? and where is it located? ive heard in ecu and heard its on passenger side kick panel. its a 90 crx si built b16 turbo and running obd1. someone please help lol. its driving me crazy that i cant figure it out.
Granny_shifter
18
Sep 17, 2012 08:08 AM
captainscorpo
Aug 11, 2007 09:00 AM
