CRVTEC HELP
Old Nov 9, 2009 | 07:10 PM
tepasoelrolo's Avatar
Default CRVTEC HELP
hello i am doing a crvtec swap i have a 2000 b20z block and a jdm b16a head i was wondering if i need new pistons for the swap or can i use my stock b20z pistons for the vtec head need help thanks ive read that the intake valve reliefs are not sufficient in size for a VTEC head is it true or can i use me stock pistons
Old Nov 9, 2009 | 07:27 PM
matt da jdm junkie's Avatar
Default Re: CRVTEC HELP
http://www.zealautowerks.com/bseries.html do work i got 10.04 to 1 from ur telling me
Old Nov 9, 2009 | 07:28 PM
ek-g6's Avatar
I wouldn't see why you couldn't use your stock b20 pistons. I have used he b20z with type r head and had some good results. If your planing to do some internal work, then I doesn't matter, cause your going to change it out anyways. A good dyno tune will do wonders tho.
Old Nov 10, 2009 | 10:41 AM
ok thanks i will then use it thanks for the quick replies i will keep you posted on my build
J_SHADOW
May 26, 2008 06:37 PM
silvercrxsir
May 1, 2006 03:21 PM
DaNish
Oct 21, 2002 09:31 AM
ahki
Apr 10, 2002 08:45 PM
