02 coupe accord EX passenger side leak
Old Nov 9, 2009 | 03:53 PM
tnk's Avatar
tnk
Default 02 coupe accord EX passenger side leak
it only seems to leak when its pouring outside on/in the front passenger floor board, still not sure if it only happens when the car is in motion or sitting still. i searched just about all the threads on this problem. i checked the 2 drain tubes in the moonroof and the one coming from the fire wall in the engine bay. i fed weed whacker line as far down as it would go in the tubes where the moonroof is then pulled it out and blasted compress air down in both tubes. i stuck wwl in the ac drain to remove debri but nothing came out.
i looked under the dash but didnt see anything obvious. i did see a semi-clear tube coming from the center of the dash to the foot area into a rubber grommet with 2 holes which the semi-clear tube was in 1, but the 2nd hole had nothing, is something else suppose to be in the other hole? could this be the culprit? well shale see since theres a FREAKING HURRICANE coming. i'll keep u all posted
Old Nov 9, 2009 | 04:07 PM
redbull-1's Avatar
Default Re: 02 coupe accord EX passenger side leak
Don't know if this might be your problem; but, this guy had to use a shop-vac to suck the water out of the drain tube on his Accord to fix his problem. His may be for a different generation Accord; but, most of the Honda designs do not change too much.
http://www.driveaccord.net/forums/sh...ad.php?t=32646
Old Nov 9, 2009 | 04:53 PM
tnk's Avatar
tnk
thanks redbull-1, i'll definitely look at this when i get home
Old Nov 13, 2009 | 07:04 AM
tnk's Avatar
tnk
i pulled the carpet and didnt see anything like what were in the pictures. i'll search through the 6th gen accords tho to hopefully find a solution.
fortunately we missed the hurricane but found out it's dripping on the right side somewhere
fquint74
May 17, 2017 06:38 AM
slushdog
Dec 23, 2013 07:20 PM
solex
Honda Civic (2001 - 2005)
Apr 28, 2011 07:21 PM
mxerchick83
Jun 22, 2010 11:02 AM
DaiJekBok
Aug 19, 2008 07:01 AM
