1991 Accord EX Sport Mode problem
Old Aug 31, 2002 | 11:00 AM
zcoker's Avatar
Default 1991 Accord EX Sport Mode problem
I have a 91 Accord EX automatic that won't go out of Sport Mode--nothing happens when I press in or out the sport mode button and the light in the dash stays on either way. The transmission shifts ok up to third but stays in third (Sport Mode). It's annoying when driving because of the high revs, especially on the highway. Anyone have a clue as to what might be causing this? Thanks.
Old Aug 31, 2002 | 12:18 PM
bill-71SS's Avatar
Default Re: 1991 Accord EX Sport Mode problem (zcoker)
bad trans controller
Old Aug 31, 2002 | 12:30 PM
CardDealer's Avatar
Banned
Default Re: 1991 Accord EX Sport Mode problem (bill-71SS)
Modified by CardDealer at 4:18 PM 11/17/2006
Old Aug 31, 2002 | 02:25 PM
zcoker's Avatar
Default Re: 1991 Accord EX Sport Mode problem (schlit)
I know what you mean because I took that button apart and it was a hell to get back together again....it seemed ok, with no faults. Any ideas on how to get the normal shift patterns back?
Old Aug 31, 2002 | 02:42 PM
oldskool_rex's Avatar
trans controller!?! That is like saying the ECU is bad because of a check engine light. If you pick up a helms manual it can give you some diagnostic tips on that condition. I know that certain "S" light patterns are like engine codes for the tranny. Sometimes it is an indicator that you need a new VSS.
Old Aug 31, 2002 | 03:27 PM
mrvinyl33's Avatar
New User
What is that sports mode all about? I have a '92 so yah I don't have it. Co-worker has a '91 and thought I must...but what's it all about considering it was gone after '91?
Old Aug 31, 2002 | 08:15 PM
91GreyAccord's Avatar
Default Re: 1991 Accord EX Sport Mode problem (mrvinyl33)
Its a torque converter. Keeps your car in 3rd gear longer for more power. I usually leave mine on, but the little green light gets annoying
Old Aug 31, 2002 | 08:59 PM
hepcat's Avatar
the speed sensor is bad, same thing happened to me, is like a $100 not tohrd to replace
Old Sep 1, 2002 | 07:44 AM
zcoker's Avatar
Default Re: 1991 Accord EX Sport Mode problem (hepcat)
I have the Haynes manual and they leave most of the automatic transmission stuff out, as usual. I would not guess that the transmission ecu is the problem but more the speed sensor, like someone else suggested. I think that I have an extra one, so I will test it and see what happens.
Old Sep 1, 2002 | 03:29 PM
bill-71SS's Avatar
if your speedo works,guess what,it's not the sensor
Old Sep 1, 2002 | 06:11 PM
fixhondas's Avatar
Could be a bad transmission control unit- you can try disconnecting the battery and this soemtimes will reset it. These are a known problem.
Old Sep 2, 2002 | 04:29 PM
gringo7718's Avatar
Default Re: 1991 Accord EX Sport Mode problem (fixhondas)
i have had all of these problems with my 91 the light started to flicker on the highway at first then downshift to third and not go to fourth- i replaced the trans computer. then the spedometer became sporadic and started slipping or something so i replaced it with my friends jdm b16 electronic speed sensor. i was suprised but it worked! check the codes it will tell you whats up
pstevens90
Apr 27, 2014 01:35 PM
speed1221
Apr 6, 2009 09:25 PM
ronnel97
Oct 7, 2008 10:17 PM
ttmlt4ht
Feb 3, 2007 10:33 PM
