High compression
Old Nov 9, 2009 | 08:48 AM
jdm as fk's Avatar
Default High compression
Does anyone know how high of compression you can run and still run 93 octane pump gas?
Old Nov 9, 2009 | 09:10 AM
Top Ramen's Avatar
Default seriously?
We really need a 99th thread asking this question?
Try the search button at the top.
Old Nov 9, 2009 | 10:19 AM
VEGAN_EG's Avatar
Default Re: seriously?
X2 it works pretty well
Old Nov 9, 2009 | 10:40 AM
all-mtr-teg's Avatar
Default Re: High compression
If tuned properly, around 12.5-13:1
Old Nov 9, 2009 | 05:34 PM
f20b jones's Avatar
id go 12-12.5 just to be safe 13.1 can be tunned but sometimes you can make less compression and more horse power im running 12.3 seems to work good for me.
Old Nov 9, 2009 | 07:55 PM
jdm as fk's Avatar
alright thanks im thinking about building a stroker out of my gsr this winter and looking to get as much power as posible
Old Nov 10, 2009 | 06:17 AM
killerpenguin21's Avatar
Cool, a stock sleeve stroker?
Old Nov 10, 2009 | 06:59 AM
jdm as fk's Avatar
yea.. or do you need to sleeve them?
Old Nov 10, 2009 | 07:02 AM
h2.4's Avatar
I think 12-1 will be perfectly fine for a street car on pump. much more than that and you can brag that you are "runnin 13-1" but you'll most likely have to pull alot of ignition timing to get away with it. 12-1 and keep some reasonable ignition timing in it.
Old Nov 10, 2009 | 08:32 AM
High CR doesn't automatically = Power
What stroker kit are you planning on doing? LS/B20 crank and rod combo? What cams, intake manifold, header, etc?
Old Nov 10, 2009 | 08:39 AM
Research how increasing stroke effects sidewall pressure, then get back to me.
Old Nov 10, 2009 | 08:40 AM
Teamdiesel's Avatar
I run 13.5:1 cr on 91 octane with 28* max timining at WOT, but I dear not enter vtec without race gas.
Old Nov 10, 2009 | 09:53 AM
jdm as fk's Avatar
im not sure yet i was thinking of going with the egale 85x95 but im not sure if i want to stroke it that far im trying to ask around and get some oppinions on what is best. but im going to run skunk2 pro cams and intake not sure on the header yet i just have a dc sport right now but plan on upgrading
down_the_hatch
37
Mar 30, 2011 07:36 PM
Evolsport
Jul 17, 2009 12:44 PM
ProInline4
48
Sep 13, 2008 04:00 PM
spoonEGcivichatch
Sep 18, 2005 09:51 AM
90da4dr
Mar 9, 2003 05:18 AM
