stuck in gear( need help)
i will try to keep this short,ok i was trying to do the timing on my b16 it has a ls tranny non lsd so when i went to put the crank on topdead center,the crank would only move lil like it was stuck in gear so i went to make sure it was not in gear and it wasnt,try it again samething when i jack up the driver side,i could turn the crank so before i take out the tranny i wanted some sugggestion,im thinking it may be the axles or the half shaft
