Forged pistons, Hondata s200 and motor parts Fs and Wtb
I gotta sell or trade some parts I have laying around that I was holding onto for future projects, to fund a new motor build. I'm also willing to trade for the stuff on my WTB list. You ca call or text me at (661)312-2340 for the fastest response. So let's get to the stuff I got for sale or trade. All prices are OBO.
84 mm manley pistons. Have less than 700 miles on them. wrist pins are included $200
- -12cc dish
-compression ratio approx 8:1 - 9:1 depending on cylinder head
-currently installed on ls/b20 rods with arp rod bolts. Will havethem removed or will sell them together for $240
PR4 ls/b20 rods with new arp rod bolts. Rod bolts were profesionally installed by a machine shop. rods are sized 3 $80
obd2 alternator $40
2 b series manual transmission starters $30
2 b series hydro transmission halfshafts $20
b series map sensor $20
blox gold billet cam cap plug $15
stock pr3 cam gears $15
fidanza 8 pound aluminum flywheel. It is usable but could se new metal insert plates. Which can be ordered online. $50
b series alernator brackets with mounting hardware $20
Gold spun meshes. They are 16x7 in 5x114 lug pattern. They have some scratches and curbage from the original owner, but otherwise the look cool. The offset is perfect on my eg. hey currenty have kuhmo ecxta v710 dot slicks mounted on them. They hold air but need to be replaced due to wear. I want $350 for the meshes.
eg/dc rear lca's with sway bar mounts. Bushings are still good. $20
eg/dc stock front upper control arms $15
tien eg/dc front strut bar $100
password jdm black rear strut bar $60
now to my wtb list. I'm willing trade anything listed but also have cash in hand. I need this stuff asap. I don't mind if is new or used.
-forged 81mm 9.5:1 -10.5:1 compression pistons
-forged gsr rods
-new gsr/itr oil pump
-new gsr/itr water pump
-skunk2 pro 1 cams
-toda timing belt
-b series valve cover
all my prices are obo. You can call or text me at (661)312-2340
thanks
- -12cc dish
obd2 alternator $40
-forged gsr rods
-skunk2 pro 1 cams
-toda timing belt
thanks
Bump TTT....
So then your not using the 81.5mm pistons... Yo just hold on to them cuz I might just pick them up.
Do you have the tool to loosen up the arp bolts? Let me have it lol
Naw. the shortblock I bought today is 81mm and I cant afford to bore it, plus the compression is a bit high for my jrsc. I don't have the tool sorry.
still got the hondata? and do u still need a b series valve cover? i have a polished b16 valve cover that has the moon cuts in it and i have a stock valve cover that has just been sand blasted (ready for paint).. id b willing to give u either one and cash for ur s200.. lmk wat ur willing to work ou...thanks
Thanks. The motor in my daily driver melted a piston on my drive home from getting it tuned :-( so now I gotta build a new one asap so I'll have a car to drive. So I need to sell this stuff fast. Thus the cheap prices
ALL FOR SALE TAKE A LOOK
https://honda-tech.com/zerothread?id=2241960
