HELP! DC2 rear quarter glass removal
Old Nov 8, 2009 | 10:26 PM
Stryker's Avatar
Default HELP! DC2 rear quarter glass removal
i need to know how or where to go to, to get it pulled. if i can do it myself that is a plus. respraying my car this winter. and i hope to start prepping in 2 weeks
Old Nov 9, 2009 | 05:46 AM
miguel329's Avatar
Default Re: HELP! DC2 rear quarter glass removal
they sell a window removal kit.... its not hard you could even use guitar strind ive done it a few times. good and youtube videos out there.
Old Nov 9, 2009 | 12:43 PM
Stryker's Avatar
thanks, i just don't want to shatter the glass
Old Nov 9, 2009 | 01:58 PM
bakertime's Avatar
Any auto glass company, and probably a lot of autobody shops can do this for you also. I've heard that removing glass can be kind of a pain yourself!
Old Nov 10, 2009 | 08:18 PM
tepid1's Avatar
It is a pain! I used fine metal safety wire. The hardest part was making a hole in the window glue to feed the wire through....
Old Nov 16, 2009 | 02:29 PM
turtleman321's Avatar
i did it onmy crx each window took less then 10 min.
Go to napa and windshield piano wire.
Use an awl and or something to put a hole in the glue.
feed piano wire through and wrap pliers around each end and use a sawing motion and go around the whole window.
if there is any glue left make sure you cut through it. you will shatter it if you pull
Old Nov 17, 2009 | 05:38 PM
ozrednsx's Avatar
I suggest not using the piano wire method mentioned above on DC2s. Ive had bad experience using it on my integra. The metal wire method works great but only if you can remove the rubber molding which you cannot in the DC2. The DC2 quarter glass and window molding is one piece. I tried using this method without damaging the rubber but i ended up taking chunks off the rubber molding.
Plus the window has 3 plastic clips integrated to the window molding which the piano wire cant cut through.
What i ended up doing is just getting a razor blade and welded it to a metal bar for some leverage. If you cant do that just have it removed professionally which cost around $25 per window which is better than paying $300 for a brand new quarter glass.
Old Nov 17, 2009 | 06:24 PM
Spawne32's Avatar
do not use piano wire, call a glass company to come out and remove them, they are glued in with urethane window adhesive and virtually impossible to remove without the cutting tool that the glass companys use, ill take some pics tomorrow
Old Nov 18, 2009 | 12:42 PM
Spawne32's Avatar
Old Dec 13, 2009 | 05:01 PM
integrada9's Avatar
what did u use to glue it back???
Old Dec 13, 2009 | 05:02 PM
Spawne32's Avatar
3m fast cure urethane glass adhesive
ScrapinSi
Nov 7, 2009 04:48 PM
E.Honda
13
Sep 7, 2006 12:54 PM
y49crxsi
Feb 21, 2004 05:53 AM
swtcivic93
Jun 18, 2002 10:12 PM
