H22a ef problems
Old Nov 8, 2009 | 10:03 PM
ef_ftw73's Avatar
Default H22a ef problems
Hi everyone, I have an h22 ef and I'm having some problems.
When rev the car it seems like it gets stuck and does not want to rev up like there is a delay and I'm not sure what it is, I'm stumped. I've switched out 2 different throttle cables to see if that could have been it but no, it's not, does anyone have any ideals?
Thanks for everything, Christopher
Old Nov 8, 2009 | 10:15 PM
theft24's Avatar
Default Re: H22a ef problems
do you have every sensor pluged up? dx, si? give us some info
Old Nov 8, 2009 | 10:24 PM
ef_ftw73's Avatar
It is a dx, and I checked all the plugs and there all hooked up. I'll run through it again in the morning, and I'll let you know!
Old Nov 8, 2009 | 10:27 PM
theft24's Avatar
did you properly convert it from the dx?
Old Nov 8, 2009 | 10:38 PM
ef_ftw73's Avatar
Honestly I do know know, I had a guy that works at a shop convert everything, I'm gonna take it to mainstream after my alignment and see what they can diagnose
Old Nov 9, 2009 | 04:58 AM
~sp33~'s Avatar
EFB055
So the car is bogging?
Perhaps you should just take it to a mechanic to get repaired, i don't mean to sound offensive, but trying to 'fix' an engine when you don't know much about them can be expensive and problematic.
Old Nov 23, 2009 | 11:27 AM
ef_ftw73's Avatar
the car is at the shop right now, so ill let everyone know
Old Nov 23, 2009 | 12:27 PM
bar'dh22's Avatar
sounds like they didnt wire the tps right
Old Nov 23, 2009 | 05:37 PM
h22apwrdcivic's Avatar
sounds like your throttle plate has carbon build up around it and it needs to be cleaned. i keep an old tooth brush for this and get throttle plate cleaner and spray it in there and use the tooth brush to get it all loose then use a rag to wipe it clean. WAAALLAAA no more sticking throttle!!
akouznet
Nov 12, 2008 10:57 PM
tougetuned_ef
Apr 19, 2007 04:56 PM
davidcrx89
Jun 23, 2006 09:12 AM
josholio
Jun 23, 2005 11:53 PM
