Suspension & Brakes Theory, alignment, spring rates....
INTEGRA (DC2) & CIVIC (EK) LCA??
Old Nov 8, 2009 | 08:09 PM
A.R's Avatar
A.R
Default INTEGRA (DC2) & CIVIC (EK) LCA??
can the EK (96-00 civic) rear lower control arms work on a 97 DC2??
Old Nov 9, 2009 | 10:06 AM
STOCK_SOHC_DX's Avatar
Default Re: INTEGRA (DC2) & CIVIC (EK) LCA??
Use the search, normally I answer this question but I believe it came up maybe 10 time within the last 30 days.
Old Nov 10, 2009 | 08:25 AM
A.R's Avatar
A.R
so far from searchin i picked up that the EK LCA is longer than the EG, DC2 LCA.
does that mean it definitely cant work , or will it work but make the rear of the DC2 higher??
Old Nov 10, 2009 | 08:31 AM
A.R's Avatar
A.R
does anyone have experiences with BLOX LCA's for the DC2?? im thinkin about buyin a pair from Ebay, jus wanna kno if there worth it. thanks
Old Nov 10, 2009 | 09:57 AM
The bushings won't last and the sway bar mount hole is in the wrong place.
Old Nov 12, 2009 | 02:37 AM
fastrxu's Avatar
^^^ this guys know his stuff
When he does pushups he actually pushes the earth down instead of the other way around (chuck norris)
And no dc lca arent interchangeable dc and eg yes
Old Nov 12, 2009 | 04:59 AM
A.R's Avatar
A.R
thanks for the replys bro.
wat about the skunk2 rear lca's?? would u recommend gettin those instead??
Old Nov 12, 2009 | 05:52 AM
SoTexDC2's Avatar
OEM is your cheapest, most reliable option. If you want aftermarket, go with Function 7.
Most of the other LCA manufacturers have a bad reputation as far as bushing lifespan goes. Some have misaligned swaybar mounting holes as well.
Old Nov 12, 2009 | 06:32 AM
batallic's Avatar
yur camber is guna be more positive if u use the dc/eg lca
bushings suck
same as ^^
OEM or function7 lifetime warranty on bushings and arms
Old Nov 12, 2009 | 11:29 PM
Skunk2 LCA's are ok but If I had to go with aftermarket, it would be Function7 cost a little more than Skunk2 with lifetime warranty bushings included.
92integraVTECgsr
Apr 21, 2010 03:58 PM
stealth_EK4
Suspension & Brakes
10
Mar 23, 2010 08:15 PM
stevel
Suspension & Brakes
Jan 5, 2007 10:50 AM
jetpilot
Suspension & Brakes
Aug 2, 2005 09:34 PM
