96 ek hatch-----missouri
DOES NOT RUNNN. BENT VALVES. WILL NEED TOWED
ENGINE
More pictures in this link
http://kcsr.org/showthread.php?t=41218
97 Gsr swap with 70xxx miles
Big tube hytec tri y header
apexi 2 1/2 exhaust
Skunk2 tuner series cam
Blox adjustable cam gear
RC 450 injectors
chipped ecu on chrome
blox velocity stack intake
skunk2 pro series intake mani
Twin loop replica muffler
walbro 255 fuel pump
supertech valve springs and retainers
SUSPENSION
Cheap lowering springs
Front and rear camber kit
skunk2 front and rear swaybar
INTERIOR
99-00 si front and rear seats
si gauge cluster with 138xxx
Skunk2 shortshifter
Skunk2 shiftknob
EXTERIOR
Saab green paint(engine bay and door jambs done)
2000 front end with ebay foglights
CTR front lip in black
JDM side marker fenders
overall its a really clean car. there are two dents on the driver side due to shopping cart at walmart. rear interior is currently out with all the sound proof taking out as well. Car is extremely clean and gets alot of heads turning. If you had a motor to swap youd have a pretty nice car.
mitch
4176318873
ENGINE
apexi 2 1/2 exhaust
RC 450 injectors
SUSPENSION
INTERIOR
Skunk2 shortshifter
Skunk2 shiftknob
EXTERIOR
mitch
4176318873
trade you my coupe if your interested now...
http://www.hondamarketplace.com/show....php?t=2646761
central MO is where i live. i have access to a truck and trailer so i have no problem towing it to my house. how did it bend valves? timing belt snap i assume?
to timing belt didnt break. it wasnt even loose. i think it was slightly bent before i got it and i just happened to finish it off. So your wanting to do a straight across trade? i live in sprignfield mo
so the valves are the only problem? springfield is only 2 hours or so from me. can i come look at it sometime this week? that way you can see my car as well. have you pulled the head and checked the valves
it cracked the inside of the block and did damage to the bottom of the head. i was told id have to buy a new motor. i dont really wanna get rid of it cause ive put so much money into it
just because a car has a salvage title doesnt mean its all ****ed up. i have someone looking at my car tonight anyway so if he decides to buy it il give you a call
