JDM H22a tach not working!
Old Nov 8, 2009 | 07:54 AM
shiux's Avatar
Default JDM H22a tach not working!
I have a JDM H22a swapped into my USDM Si (H23 stock). I'm running a JDM P13, and using the USDM external coil dizzy.
My tach hasn't worked since the swap!
What wire sends the rpm signal?
Will running a USDM dizzy w/ JDM ECU be an issue?
someone please help me!
Old Nov 9, 2009 | 06:18 AM
blaze.1's Avatar
Default Re: JDM H22a tach not working!
https://honda-tech.com/forums/honda-prelude-4/how-do-i-hook-up-vtec-h22-swap-2555489/
Old Nov 9, 2009 | 01:49 PM
shiux's Avatar
I found the wire you said, it runs to my VTEC solenoid... is that right??
Old Nov 10, 2009 | 05:42 AM
blaze.1's Avatar
yeah, thats right.
Old Nov 10, 2009 | 02:09 PM
shiux's Avatar
hmm.. so I'm back to square one then.
The blue wire is supposed to send the signal, so by my logic, with the test light being grounded on the battery, and poking the blue wire with the car running, I should get a signal to the test light right?
Because as of right now I get nothing that way, but if I put the test light on a power source and touch the blue wire, I get the light.
Its like the blue wire is acting as a ground, not a signal/power source...
shiux's Avatar
I will ****ing paypal someone 5 dollars if they lead me to the answer to my problem. seriously.
Old Nov 10, 2009 | 05:00 PM
Scudweiser's Avatar
test the continuity between the blue wire at the dizzy and the TCM using a multi meter, if thats ok, then test it from the Dizzy to the Tachometer connector. he blue wire splits somewhere in your harness, with each end going to either the tach or tcm, maybe that split is broken or shorting.
Old Nov 10, 2009 | 05:18 PM
shiux's Avatar
I'm going to feel stupid in the morning, but TCM?
I was thinking maybe I un-pinned the wire for the RPM signal when I was trying to get the damn H23 ECU out, what color wire is it/slot on the ECU side of the harness?
Old Nov 10, 2009 | 06:11 PM
Scudweiser's Avatar
tcm= transmission control module, its just a solid blue wire all of the way through, according to my chilton book the tach wire doesnt go to the ECU , it goes to the tcu
Draven8795
13
Dec 16, 2011 05:37 AM
slimjimdanny
Jan 31, 2007 07:35 PM
beat_nut
Nov 16, 2004 02:45 PM
turbohf
Sep 28, 2003 01:11 AM
projectcrx
May 15, 2002 10:36 PM
