Which ECU is better?
Old Aug 31, 2002 | 06:49 AM
brownman72000's Avatar
Default Which ECU is better?
I have I/H set up and what to get a ECU. The two I am comparing is the one Kenji makes vs this JUN one http://cgi.ebay.com/ebaymotors/ws/eB...tem=1854697710. With the JUN one, is it safe to run on all factory valvetrain and shift at like 9? Some people say that the stock cams are safely capable of running it while other people say they need to be upgraded. Which ECU unit do you suggest for just an I/H setup. Thanks!
Old Aug 31, 2002 | 07:51 AM
Cosworth's Avatar
Default Re: Which ECU is better? (brownman72000)
Kenji's P28 re-chipped ECU is my vote.
I would also add V-AFC to fine tune your setup afterwards.
Old Aug 31, 2002 | 07:53 AM
B2FiNiTY's Avatar
From what people have said:
Kenji
Old Aug 31, 2002 | 11:47 AM
rainmanEK's Avatar
big strong guy
Default Re: Which ECU is better? (B2FiNiTY)
check my sig!! you will be very happy!! good luck, eric
Old Aug 31, 2002 | 12:15 PM
Ryuji's Avatar
New User
Default Re: Which ECU is better? (Cosworth)
Sorry, I'm a newbee but I thought a VAFC made the same thing a new ECU
with the advantage to be "tunable"
I was wrong then...
Old Aug 31, 2002 | 01:07 PM
guyuenvy's Avatar
Default Re: Which ECU is better? (Ryuji)
Get kenji wont regret it
Old Aug 31, 2002 | 02:02 PM
kenji's Avatar
25 Year Member
Default Re: Which ECU is better? (guyuenvy)
Thanks for the kind words guys. I really appreciate it.
Brownman72000 email me for more info on one of my ECUs and harnesses.
-kenji
moekhanafer
May 13, 2005 07:48 PM
slow91crx
Apr 27, 2005 05:23 AM
TeamDOHCside
May 11, 2004 08:55 AM
range
Dec 23, 2003 06:49 AM
