eg dash trim removal damaged! help
took my anger out on my car and damaged the... im guessing its called the dash trim?? its the gray long piece where the radio den is, the cruise control button, and the ac/heater unit is. i also damaged the bezel too. i want to remove it and clean it up and bit and replace it but with out damaging the dash.
heres an example of the dash. i want to replace the bezel and the grey dash trim. neeeeeeeeeeeed help!!!!
http://c3.ac-images.myspacecdn.com/i...c152e8710a.jpg
you have to first take out the climate control and i think it is plastic rivet that holds the gray piece on. It may be screws i cant remember for sure. anyways pull the climate control out and then it should com off of the dashboard. if they are the plastic rivets that holds it on you will have to file the plastic down and reattach with screws and washers
if the dash is out then it shouldn't be too hard. 6 screws from the back for the grey piece. almost impossible without removing the dash though.
if i don't say almost then someone will argue with me Lol
polyhonda
Jan 21, 2013 05:33 PM
sixfiveoh
Aug 8, 2009 10:43 PM
