will I lose power with a ------ exhaust size??
Hey I got a 95 gsr in my hatch.Its stock with just bolt ons. What exhaust size should I get?? 2"...or 2.25"... or 2.5".... or 3"..??
my buddy said I can run a 3" with a good tune and not lose power. WHo's right???
thanks guys
thanks guys
60mm is good. Anything bigger is too big.
http://www.team-integra.net/sections...p?ArticleID=48
3'' is too big for bolt ons for sure... Its like when you use a bigger intake manifold (Venom) on a stock car, too much air flow.. it just chokes on it and there in lies power loss.
Just go 2.5.
Just go 2.5.
2.25-2.5, and the Ti articles should giv you a good idea as well.
most catbacks are 2.36-2.38 and 2.36 being the most common
if you are doing customthen you'd should do 2.25 or 2.5 mandrel bending.
3" crush bent is supposedly equivlent to a 2.5 mandrel but it still is going from 3 > 2.5 on the bends and back to 3... not even flow
Here are some pictures of a custom 2.5" Exhaust.
SMSP Header to the SMSP High flow cat
Extra O2 bung, if I ever have to go back to OBD2
I took off a Comptech Cat-back. ~2.36"
If you are planning to stay with bolts-ons on your car you will never see the benifits of a 3". Keep in mind 3" will sound louder and weight more. If your planning major engine work, lets say over 225whp a 3" will be good.
^^Just put a cat on my car for emmissions and it feels like there is more torque in lower rpm. But in higher rpms 3000+ definitely feel less power than before with a test pipe.
I can't believe this thread. This is the stupidest thing ever, Exhaust does NOT increase your performance by any noticeable amount unless you've got a build and are required to put it on. You're just drawing attention to yourself. I would save your pennies and go for a more useful mod personally.
If you wanna make power.. reguardless of what anyone tells you..
you have to run 2.5+.. I run 3'' on my daily and have even had thoughts of going 4''..
when you take a crap in the bathroom, you want it all out in no time. thats somewhat same with a car
