6spd swap into a B16
Old Nov 7, 2009 | 07:37 AM
00EckoSI's Avatar
Default 6spd swap into a B16
i searched this for about an hour and only found swap infor for K series engines..is it possible to do a 6spd swap into a B16A2 motor?
Old Nov 7, 2009 | 07:41 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: 6spd swap into a B16
No, but why would you want to do this?
Old Nov 7, 2009 | 07:42 AM
00EckoSI's Avatar
its something that i want to do
Old Nov 7, 2009 | 07:49 AM
nemisish20's Avatar
Wheres my titleeeee!
kseries rotate the other direction. Unless u want 6 reverse gears go for it.
Old Nov 7, 2009 | 07:53 AM
00EckoSI's Avatar
what 6spd tranny would even bolt up to a b16
Old Nov 7, 2009 | 07:54 AM
Deetz's Avatar
Crazy Honda Guy
you also can't modify the inside of a b series tranny to take one either. I would give up on the idea
Old Nov 7, 2009 | 07:55 AM
00EckoSI's Avatar
im not going to break my bank to do this i was just wondering if it was possible at all
Old Nov 7, 2009 | 07:56 AM
allboost4u's Avatar
so basely the rotate apposite to a clock
Old Nov 7, 2009 | 07:57 AM
gibsanez's Avatar
NO
/thread
Old Nov 7, 2009 | 08:01 AM
Unseen Racer's Avatar
only way to do a 6-speed on your car is to do a K swap
Old Nov 7, 2009 | 08:13 AM
that_boy_sammy's Avatar
ive never had enough space to even reach the end of my 5th gear
Old Nov 7, 2009 | 08:15 AM
00EckoSI's Avatar
ive came close a couple times..ive driven 6pds before and i like them i was just wondering if it was possible..guess its not because im not doing a k swap i like the b16 motor
Old Nov 7, 2009 | 08:17 AM
nemisish20's Avatar
Listen broski. Dont stress it. If you like having a low gear on the highway just get a GSR trans and put an LS 5th gear in it. Not really worth it. Stick with the b16.
Old Nov 7, 2009 | 08:18 AM
00EckoSI's Avatar
haha im just gonna stick with what i have and continue to work on the "boost" project
Old Nov 7, 2009 | 08:21 AM
Deetz's Avatar
Crazy Honda Guy
You know the thing that kills me about these threads is people don't understand the gearing. You don't get an extra high gear the addition of a 6th gear, lol
i'll give you an example.....
The 02-04 RSX, the 1st gear and 5th gear in a base model, are the "same" gears found on the 1st gear and 6th gear on the 6 speed type S model. The "only" advantage you get, is the gearing in between.
Old Nov 7, 2009 | 08:24 AM
nemisish20's Avatar
you dont get a high gear. It just another gear. If anything it helps get better Gas mileage.
Old Nov 7, 2009 | 08:30 AM
vtectouge's Avatar
Ive seen one in Thailand b18c block with a b16b head, never seen on a b16a before accept in GT4 hihi, a custom gearbox will do but it cost more then a k swap..
Old Nov 7, 2009 | 08:33 AM
00EckoSI's Avatar
yeh im just going to stick with my boost project
Old Nov 7, 2009 | 10:56 AM
jcdimvic's Avatar
I think you should boost the K, you get your boost and you get your six speeds.
Old Nov 7, 2009 | 03:59 PM
pauldizzle89's Avatar
uh.... wrong, you could go hella crazy and do an f20c swap, it's six speed and a rwd conversion
Old Nov 7, 2009 | 04:13 PM
fastrxu's Avatar
You could do a j swap and have 6 speeds
Dude you look up the civette you can do anything you want. Is it practical? Its up to u
Old Nov 7, 2009 | 04:54 PM
hushypushy's Avatar
another alternative: F2K. Keep your F20, keep it FWD, and you have 6 speeds!
Old Nov 7, 2009 | 05:04 PM
93egSLEEPER's Avatar
because thats cheaper and easier then doing a k swap right? this thread as a waste.
Old Nov 7, 2009 | 05:22 PM
VTAC-KAT's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/6-speed-transmission-b16-129630/
DelSloSiwhat?
Mar 9, 2013 05:58 PM
DelSolBraap
42
Jan 25, 2010 09:35 AM
95EG2
15
Dec 2, 2009 01:34 PM
MugenManR
Jul 24, 2007 08:37 PM
TurBoXBirD16
Mar 25, 2002 05:52 AM
