99 civic dx idle issue
Hello all. I was wondering if someone out there can give me there knowledge. I have a 99 civic dx automatic. The head gasket blew so I replaced that, and the plugs, rotor, cap and wires. The timing is set correctly. The car idles ook when cold but when it warms up and i come to a stop the car dies so I have to put it in nuetral and give it gas and break. There is also a hissing sound comming from the back side and it rides really rough and it is louder than before. There is no effect on power.
Any takers!!
Thanks
Jon-Lee
Any takers!!
Thanks
Jon-Lee
Maybe try cleaning your IACV? This can get dirty and create an unsteady idle over time, I may be wrong though, I've never heard of a car just dying from it... it's located on your throttle body by the way
You've probably got a vacuum leak somewhere around the intake manifold. Check to make sure all the hoses are plugged in, if they are you can try spraying a can of carb cleaner at various spots to check for leaks in the gasket etc.
Mugen_freak_si
Mar 26, 2017 04:49 AM
hondamiser
15
Mar 30, 2015 04:49 AM
dllnzek
10
Jul 24, 2012 09:49 AM
maxash0775
Nov 17, 2009 06:21 PM
