99 civic dx d16y7 -- idle surges and CEL is on
Im having issues with the idle i changed the thottle body gasket, intake manifold gasket is fine,coolant is full, check engine light (C.E.L)is on, car at idle surges, mass air flow senor (M.A.S) one wire is torn almost all the way at the sensor itself. I tried adjusting the idle but it just keeps surging. I triple checked everything and cleaned the thottle body too. IM lost on what to do, i also disconnected the battery so it can reset, but it gave me the same issue. If anyone have any ideas it would help me out a lot thanks.
Re: My 1999 honda civic dx d16y7
I already went to autozone and they got the code it said something about the idle or the air flow . I doubt it's the idle air control (I.A.C) because it was working today before i started to fix it and once i went to go adjust the idle it started to **** up on me. Im trying to see what else it could be im fresh out if ideas for now.
Pull the code yourself. Check the Stickies for a how-to. If you can give us the actual, exact code, we can help. Without that, we can't really help you without randomly spitballing, which never ends well.
Re: 99 civic dx d16y7 -- idle surges and CEL is on
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
the check engine code is p0505..the idle bounces..feels like the car will stall..sounds like a gay version of a 2 step at neutral..help please
i cleaned the iacv and it def helped..burped the radiator..now it idles a lot better but still not like it used to..i guess im gonna have to adjust the idle speed..no check engine yet i have to wait for the ecu to reset and hopefully it works out
travie_vtec
25
02-08-2013 09:43 PM
joshua89
08-20-2011 01:47 PM
