I need help drilling these 2 holes
Old Nov 6, 2009 | 07:25 PM
Rok_Stok's Avatar
Default I need help drilling these 2 holes
The bolt holes on my header and test pipe don't line up. Should I....
1. Drill new holes?
2. Elongate the existing holes?
The flange is 1/2" thick by the way! I have a hand drill and some drill bits.
How would you go about cutting into 1/2" thick steel?
Old Nov 6, 2009 | 07:49 PM
FRESHTEG's Avatar
Default Re: I need help drilling these 2 holes
local muffler shop will get it done for cheap
Old Nov 6, 2009 | 07:51 PM
tmzcivic's Avatar
Those holes look way too close to the pipe itself. Make sure there is enough room for the washer/nut or bolt head before you drill.
Old Nov 6, 2009 | 08:12 PM
thumper64's Avatar
Cut the old flange, get a different one welded on or clamp it on.
Old Nov 7, 2009 | 10:42 AM
Rok_Stok's Avatar
I ended up drilling two 3/8" holes and that wasn't that hard at all. I haven't installed the header and test pipe yet because the donut for the header is too big for the test pipe, which was advertised to be 2.5" also. So I'm trying to grind off material on the donut gasket.
SR20S13
Welding / Fabrication
Mar 10, 2011 06:45 PM
victorpapa
Sep 3, 2005 11:11 PM
ludermark
Sep 14, 2004 09:07 PM
-Whitey-
Jan 27, 2003 11:58 AM
