91 crx Si no spark
Old Nov 6, 2009 | 02:07 PM
spencer47's Avatar
Icon3 91 crx Si no spark
So here's the deal. I have a 1991 honda crx Si with a b20b motor swap with a gsr tranny. I am using a obd0 to obd1 ecu jumper harness and i have converted the dizzy to obd1 since its a b20 which is obd2. anyways i am getting fuel which means my main relay is fine but i am getting EXTREMELY little to no spark. idk what the problem is. i think i need a new ignitor because of this problem. but idk.
PLEASE HELP
any help would be great
Old Nov 7, 2009 | 05:47 AM
spencer47's Avatar
Default Re: 91 crx Si no spark
bump
Old Nov 7, 2009 | 03:04 PM
spencer47's Avatar
ttt
Old Nov 7, 2009 | 05:46 PM
spencer47's Avatar
ttt
Old Nov 7, 2009 | 05:49 PM
beansandrice's Avatar
I would go straight to the Harness grounds. Then I would jump on the Dizzy wiring. If those check out I would try a different coil. Then the Ignitor chip or even easier try a known good Dizzy. Firing order etc.
Old Nov 7, 2009 | 10:18 PM
spencer47's Avatar
true. will try this tomorrow. ttt
Old Nov 8, 2009 | 08:04 AM
spencer47's Avatar
ttt
Old Nov 8, 2009 | 12:44 PM
DPSJosh's Avatar
Did you check any of the stuff that 'beansandrice' suggested? I would say he's on the right track...
Old Nov 8, 2009 | 04:24 PM
spencer47's Avatar
no i didnt. had to take care of some things. will try tomorrow or tuesday. ttt
Old Nov 8, 2009 | 07:27 PM
91CR-XSiR's Avatar
OK SO LET START WITH THIS; WAS THE MOTOR ALREADY RUNNING? HOW DID THE PROBLEM START? CHECK TO MAKE SURE ALL GROUNDS ARE CLEAN AND SECURE, ESPECIALLY T-STAT HOUSING.
Old Nov 8, 2009 | 07:33 PM
97 ek coupe's Avatar
x2 on grounds, especially thermostat
Old Nov 11, 2009 | 03:03 AM
spencer47's Avatar
been raining the past couple days. still is this morning. ttt i will try asap
Old Nov 11, 2009 | 03:32 AM
~sp33~'s Avatar
EFB055
Stop bumping the thread without trying what's already been suggested. Your problem may have been solved already.
Old Nov 11, 2009 | 05:30 AM
KINGVEM^^ED6's Avatar
X2
Old Nov 11, 2009 | 05:44 AM
ef-hatchcrap's Avatar
Try switching the 2 white wires on the chassis side plug. When I converted to obd-1 I had the same problem you are describing switched the wires car ran great
Old Nov 11, 2009 | 05:45 AM
crx_si-r's Avatar
how did you make the distributor work? jumper harness? repin the plugs? if you did this the white and cream colored wires are most likely in the wrong spots
Old Nov 11, 2009 | 11:36 AM
spencer47's Avatar
i do not have 2 white wires on the chassis side plug.
Old Nov 11, 2009 | 11:51 AM
spencer47's Avatar
both grounds are good.
Old Nov 11, 2009 | 11:52 AM
spencer47's Avatar
switched the cream wires and still no spark.
Old Nov 12, 2009 | 03:54 AM
spencer47's Avatar
any help guys?
Old Nov 12, 2009 | 05:17 AM
91AllMotorCRX's Avatar
New User
How do you know your not getting spark? is the motor just not starting or did you pull the wires and look for spark? Could be bad wires/plugs!! also try useing a friends known to work dizzy and see if it works in your car. If its still not working go further into wiring and grounds.Are you using a conversion harness or did you do the re-pin? Double check all wiring for the dizzy and resistorbox(if using obd1 injectors it need to be converted to send 12v). Add 4ga grounds in place of stock front ground, connect from cylinder head to chassis to engine block.
Old Nov 12, 2009 | 11:14 AM
spencer47's Avatar
i had the dizzy repined and my grounds are good. i know i dont have spark because i took a plug out and a spark plug and put it to the chasis and there was not any spark at all.
i think it might be in the ignition module or my knock sensor. going to try and check these things. will keep you guys posted.
Old Nov 12, 2009 | 05:29 PM
New User
The knock sensor won't cause it to not fire. Ignition Module can cause it to not start but motor usually wont crank over if the module is bad.
I would put all wiring back to stock and contact rywire and get a new obd1 dizzy and a conversion harness that will plug right in and match correctly, no repinning required! Make sure your ECU is obd1 as well as your injectors. If you decide to run obd0 injectors you will need the stock resistor box. Also run down to your local autoparts store and pick up some new plugs and wires (NGK part #'s: ZFR5F-11 and HE82). About a hour of labor and youll be up and running, no issues.
Old Nov 14, 2009 | 05:48 AM
spencer47's Avatar
me and a few friends are going to test alot of things today. will post if it runs.
Old Nov 14, 2009 | 10:56 PM
dohccrxsi's Avatar
Icon3 Re: 91 crx Si no spark
PLEASE HELP
Either you've mixed the firing order up on the Ignition wires from the Distributor to the spark plugs (assuming you have it wired right), Or your distributor is DEAD, get another obd1 distributor off of a running car and try with that, if that doesn't work, Your firing order or wiring is wrong.
Beans hit it right in the head where you should have started, {POST WHEN YOU HAVE DONE SOMETHING.
tyvtec23
Oct 20, 2011 04:11 PM
cherroneballs
Jun 1, 2010 07:30 AM
sleepingciv
Apr 21, 2010 05:12 PM
c rex 88
14
Dec 27, 2005 09:56 AM
