Does your turbo dragster "buck" at constant low rpm?
Old Nov 6, 2009 | 09:57 AM
Mikey3000's Avatar
Default Does your turbo dragster "buck" at constant low rpm?
For example: you're driving back to the pits in 2nd gear at 2-3000 rpm. My **** bucks like a damn bronco. It's annoying as **** and i wonder if there's any reason it does that.
Old Nov 6, 2009 | 10:01 AM
tony1's Avatar
Default Re: Does your turbo dragster "buck" at constant low rpm?
If you have some big ridiculous non vtec cams then it can do that and if you have the old Bosch 160lb injectors it can do that. Otherwise, it should not and is probably a tuning issue.
Old Nov 6, 2009 | 10:16 AM
Mikey3000's Avatar
it has stock cams and 1600cc injectors.
Old Nov 6, 2009 | 10:23 AM
tony1's Avatar
Yeah, when it's bucking like that the a/f ratio is probably all over the place, right? You're probably right in the middle of the very non linear part of the injector flow. The best thing you can do is run it overly rich there and it will smooth it out a little.
Old Nov 6, 2009 | 11:03 AM
Urban_Indian's Avatar
I was chasing this problem for the longest time
Old Nov 6, 2009 | 11:08 AM
Mikey3000's Avatar
cool, thanks for the info.
Old Nov 6, 2009 | 11:14 AM
jnv255's Avatar
Mine was doing that, re tuned it and it dont anymore. I have 1680cc
Old Nov 6, 2009 | 01:09 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
No wideband hooked up? It's most likely a tuning issue
Westrock2000
Jun 10, 2007 06:13 PM
crxsir23
Mar 9, 2007 05:28 AM
vti444
23
Apr 9, 2005 06:44 AM
AllMoToRB18c
19
Sep 13, 2003 10:03 PM
