93 DA9 B18b1 question
Old Nov 5, 2009 | 10:23 PM
vzqz18's Avatar
Icon6 93 DA9 B18b1 question
hey guys im having some problems with my da9. and i wanna find out were would my master cylinder be located? sorry im a noob!. cause im having a rough shift from 2nd to 3rd. thank guys
Old Nov 6, 2009 | 06:54 AM
weavertime1's Avatar
Default Re: 93 DA9 B18b1 question
I am guessing that you are looking for the clutch master cylinder? If you are, you won't find it on a '93 integra. The 90 - 93 integras were cable operated clutch transmissions. If you are having issues with the 2nd to 3rd shift it could be more than just a clutch cable adjustment. You may have a interior transmission issue like a synchro or something. Good luck!
...Also your car most likely has a B18A1 unless it was swapped at one time. The A1 from '92 and '93 are identical to the '94 - '01 B18B1 anyway, but just letting you know!
Old Nov 6, 2009 | 11:01 AM
DumaDA's Avatar
really though, if your tranny is messed up, and its a ls cable tranny, just replace it, you can find one on craigslist for like 250$
Old Nov 6, 2009 | 07:14 PM
vzqz18's Avatar
thanks guys., it was handed down by cuz, anywho it was swapped for a 93 b18b1 and i adjusted the cable and the pedal is all the way up.
Old Nov 6, 2009 | 07:18 PM
DumaDA's Avatar
if its 93 it should be b18a1
Old Nov 6, 2009 | 07:22 PM
vzqz18's Avatar
idk but the car is 90 integra ls the tranny is b18b1
Old Nov 6, 2009 | 07:24 PM
DumaDA's Avatar
which would mean that the tranny is a hydro tranny then? if its from 94+, do you happen to know what the code on the tranny is?
Old Nov 6, 2009 | 07:25 PM
Double Agent's Avatar
To weavertime- B18B heads have larger ports than the B18A, different cams, PCV system, etc. There are actually a bunch of differences.
To vzqz18- 93 is still B18A, 94^ is B18B. Also, DA (90-93 Integra) transmissions are known for third gear going bad once they get up in the millage.
Old Nov 6, 2009 | 07:31 PM
vzqz18's Avatar
thank you for that info seriously im new to tegs. so to recap most likely its the transmission with the problem?
Old Nov 6, 2009 | 07:36 PM
vzqz18's Avatar
were would i find the code?
Old Nov 6, 2009 | 07:37 PM
Most likely. If it's the cable tranny then it should be the stock one for the B18A and like I said, they're known for third going bad.
Old Nov 6, 2009 | 07:42 PM
vzqz18's Avatar
oh ok gotcha so should i try replacing the cable or just save up for a new tranny?
Old Nov 6, 2009 | 09:22 PM
God-Driven's Avatar
It depends on what kind of plans do you have with the car, if you are planing on keeping it just get it rebuilt if not you can always roll the dice and get an used one
Old Nov 6, 2009 | 10:41 PM
vzqz18's Avatar
yeah im planning on keeping it. Thanks man btw nice "roll the dice" lol.
Old Nov 9, 2009 | 11:18 AM
DumaDA's Avatar
just compare the prices for how much a new tranny costs vs. getting it rebuilt. If you're from LA im sure theres some people from h-t who rebuild trannys near your area
Old Nov 9, 2009 | 09:55 PM
vzqz18's Avatar
thanks man yeah im am currently looking around for a tranny any rec.?
Old Nov 9, 2009 | 11:54 PM
DumaDA's Avatar
b16 cable tranny ftw! you'll feel so much more out of your motor just with the tranny
Old Nov 10, 2009 | 12:53 AM
boosted91REX-SI's Avatar
and have one lest ******** after paying for it!!! at least a nice one
Old Nov 10, 2009 | 08:12 AM
DumaDA's Avatar
not true. Theres alot of b16 cable trannys on craigslist for less than 400
maineef
Transmission & Drivetrain
Dec 17, 2012 05:59 PM
D C 5
May 21, 2005 11:44 AM
Inaniac
Sep 14, 2001 05:31 PM
