94 Civic hatchback will crank but not turn over
Old Nov 5, 2009 | 08:48 PM
deepdownpaul's Avatar
Default 94 Civic hatchback will crank but not turn over
My car is not starting, but will crank. Sometime it sounds like the engine goes for one or two rotation, but then dies. YOu can hear the fuel pump prime when the key is in position 2, and it smells flooded after a few attempts so I think the fuel rack is getting fuel.
I just tried a new main relay which didnt result in much change.
Any other ideas.
Old Nov 5, 2009 | 08:51 PM
DAintegraGSR's Avatar
Default Re: 94 Civic hatchback will crank but not turn over
you say the engine rotates about a two times,(is this while your cranking it) but then dies, sure its not just the battery??
Old Nov 5, 2009 | 08:52 PM
Former User's Avatar
Check for spark at the plugs. Any CEL codes?
Old Nov 5, 2009 | 09:04 PM
There is spark, as well as new plugs. Not sure about CEL codes. I know there is no code faults when you jump the test terminal over by the glove box.
When I say it rotates one or two times, it is as if the car has started because I have turned the key back from start, in it kind of just stalls out. But on other start attempts it just doesn't seem to catch, and will just crank away.
Old Nov 5, 2009 | 09:07 PM
How did this problem come about?
Is spark at the plugs bright white or weak orange or blue?
Is the mechanical timing off?
Have you measured cylinder compressions?
Old Nov 5, 2009 | 09:10 PM
EFbomb's Avatar
take cap off the dizzy and check the rotor. just cause it has spark doesnt mean its at the correct time.
Old Nov 5, 2009 | 09:21 PM
does it seem to crank faster than normal.
just asking cause you said on other attemps it just cranks away. may be your timing belt. but if it has started but then stalls it couldnt be the belt but maybe a timing issue.
any work done recently?
MRQ
Honda Civic (2006 - 2015)
Jun 9, 2019 05:48 AM
99Ek_Fred
Jul 26, 2018 11:53 PM
integrals21
Jan 8, 2010 04:45 PM
sprtbiker
Oct 15, 2009 05:57 AM
SilverGT
Dec 2, 2006 03:12 PM
