any products out there to removed 2 years of caked on dirt on window?
Old Nov 5, 2009 | 07:22 PM
JDMJUNKIEMONKIE's Avatar
Default any products out there to removed 2 years of caked on dirt on window?
my cousin in law gave me his car, its been sitting for 2 years and the windows are just plain dirty. i would wash and try to hand polish it out with the windex and it wont come off. any product out there or any solutions to getting this dirt off the window?
Thanks
Old Nov 5, 2009 | 07:26 PM
theft24's Avatar
Default Re: any products out there to removed 2 years of caked on dirt on window?
paint thiner, gas, rubing alcohol might work
Old Nov 5, 2009 | 08:07 PM
~sp33~'s Avatar
EFB055
Just be cautious in case the windows are tinted, thinners etc will probably make the tint cloudy.
Old Nov 5, 2009 | 08:14 PM
dacrxguy's Avatar
rubbing compound and op b4 you do the whole window i hope you test on a small spot
Old Nov 5, 2009 | 08:20 PM
okay. thanks i tried metal polish but that failed.
Old Nov 5, 2009 | 09:14 PM
fatCRXguy's Avatar
You could try using a razor blade on the outside, you could use it on the inside if the windows aren't tinted.
Old Nov 5, 2009 | 09:30 PM
dacrxguy's Avatar
yeahhh i think that only works on metal
Old Nov 5, 2009 | 09:44 PM
4tika4's Avatar
yeah, steel wool works to get hard water stains off. So it should be able to get anything off. just makes sure its nice and wet
Old Nov 6, 2009 | 04:08 AM
~sp33~'s Avatar
EFB055
Sounds like a great recipe to scratch the *** out of your windows.
Old Nov 6, 2009 | 06:35 AM
kelsodeez's Avatar
derp resistant
sounds like you have never tried it. ive been doing it for years and as long as you use a fine steel wool, you wont scratch anything. oh and dont use it on the inside. only the outside of the window. on most cars, the inside of the windshield had a plastic layer that will scratch.
Old Nov 6, 2009 | 06:58 AM
i tried steel wool on water stains, but i didnt think it would work on caked on dirt. i guess i can do that. since i know its safe and effective.
Thanks for all the responses. Appreciate everyones help
Old Nov 6, 2009 | 07:32 AM
mnmsddy's Avatar
try a product called bio-clean. I originally found it through my honda dealer when I parked my Odyssey too close to a sprinkler on vacation and spotted the crud out of my windows. It worked great, I know use it on my shower doors and such. I have seen it at a local glass shop as well, it was cheaper at honda. Dont try it on paint it dont work as its abraisive. I have heard toothpaste works as well.. have not tried that.
Old Nov 6, 2009 | 09:23 AM
4tika4's Avatar
if you use steel wool. Make sure you get the #0000 grade. It wont scratch. I use it all the time. and no scratches
Old Nov 6, 2009 | 09:29 AM
coreysef's Avatar
Purple power and a microfiber.-Later
Old Nov 6, 2009 | 12:36 PM
m_shake's Avatar
used to work @ a detail shop (not like $25 hand wash like $200+ detail jobs) we used fine steel wool all time, NEVER had issues
Old Nov 6, 2009 | 06:16 PM
Thanks. i just did the steel wool trick. it worked good, but i still see alittle bit of residue still left behind. either way its way better then before.
will look into that bio-clean and the purple power. Thanks for the quick responses and help.
jit01
Detailing
Aug 4, 2009 05:32 PM
Sabbotage
Jul 3, 2005 09:18 PM
91 HONDAsaurus rex
Sep 25, 2004 07:36 PM
1993ludevtec
Mar 22, 2004 03:19 PM
m0dr0cker
16
Oct 21, 2003 09:55 AM
