My car eats batteries
So I picked up my 3rd brand new battery this year today (thank you Honda for giving me them free with the battery warranty)... they did a drain test on my car and said everything was all set, but they're dead wrong I'm pretty sure
any ideas or should I just start searching everything electronic for some sort of short circuit?
Connect one probe to ground and the other to the back of the alt at the charge post(the biggest wire on the alt). At idle you should be around 13 volt and it should go up a little when you rev it. No higher than 15.5 though, you could be boiling batteries from too much voltage or... not getting enough.
Good luck with it, it's a realitivy easy fix I'm surprised your dealer hasn't figured it out after three batteries.
Last edited by Transpoquick; Nov 5, 2009 at 07:11 PM. Reason: Wheww! post count went up thanks HT and Boosted!!
I wish I could get free batteries.. lol just put the leads onto the battery and rev the engine, like transpoquick said, you should get a raise in voltage no higher than 15 but no less than 13.. maybe your car is possessed??
haha my car is a bit possessed... I didn't leave anything on, the battery would've been fine after a boost if that was the case... thanks for all the advice, I'm going to "borrow" a volt meter from school this week and check out my alternator
the batteries are free because I bought them from honda and they have a 3 year full warranty... it's not a warranty that goes with the car or anything
and the people at the dealer are idiots, of course they haven't found anything.. if it is a weak alternator do I just replace it? that will be easy enough
the battery light is not on, alternator belt is good, and my stereo is just a head unit and 4 speakers
the only thing electrical I've ever really added was a pair of fog lights, which I had for quite some time before these battery issues began
sure enough it was my alternator, I replaced it yesterday... I got an alternator at autozone, had to file the damn bracket down for an hour and a half because the fit wasn't perfect, but it has a warranty and was cheap
BIG_WILL
Nov 16, 2008 07:06 PM
I Like Hondas
20
Oct 18, 2006 01:54 PM
PINKS
27
Jun 5, 2006 05:57 PM
PINKS
13
Jun 4, 2006 09:11 AM
