gsr is slower after being rebuilt with ctr pistons
Old Nov 5, 2009 | 06:53 PM
bmwe362006's Avatar
Default gsr is slower after being rebuilt with ctr pistons
I am running a gsr block b16 head. I rebuilt the bottom end and installed ctr pistons. i have driven it about 150 miles. I got on it once and it felt considerably slower then before. (stock bottom end with worn rings). i havent done a compression test yet but will the motor slowly get stronger through the break in process?
Old Nov 5, 2009 | 06:57 PM
TunerN00b's Avatar
Default Re: gsr is slower after being rebuilt with ctr pistons
If you already drove it 150 miles, the "break in" period is done.
So, you increased the compression, didn't get the car tuned for the change, yet wonder why it feels slower...
Get the car on a dyno, get it tuned, and find out exactly what it is making. The butt dyno is a very insensitive tool at best, and a complete liar at worst.
Old Nov 5, 2009 | 07:02 PM
bmwe362006's Avatar
well at the same time i was getting on it so was my buddy in his si. lol. Before i rebuilt it the motor smoked horribly but i would still beat him by about a car and a half. Now he beat me by about two cars. I raised the compression and got much slower.....
Old Nov 5, 2009 | 07:10 PM
SergEK's Avatar
Its like 1995 all over again...
Get to a dyno and get a tune PLEASE for the sake of the motor
Keep in mind your timing maps may have to be adjusted for the compression you are running, as well as your fuel requirements.
Old Nov 5, 2009 | 08:06 PM
ILS_09's Avatar
all you need is just a tune
Old Nov 5, 2009 | 08:07 PM
PaulMc's Avatar
Painfully Stupid
You need a tune, simple as that. That's why your piston upgrade doesn't feel effective the way it should be.
Old Nov 5, 2009 | 08:23 PM
SpEeDyX's Avatar
I dont understand how someone can rebuild that motor and raise the compression and not know enough they need a tune. Also ctr pistons were a bad choice you should of just gone with jdm itr pistons.
Old Nov 5, 2009 | 10:22 PM
bmwe362006's Avatar
i know it isnt tuned but my buddy had the smae setup awhile ago and his car would run really well
Old Nov 6, 2009 | 04:53 AM
weavertime1's Avatar
...it shouldn't have without proper tuning.
Old Nov 6, 2009 | 04:54 AM
A.R's Avatar
A.R
i agree wit yall he needs a tune.
Why were the CTR pistons a bad choice???
Old Nov 6, 2009 | 07:13 AM
SpEeDyX's Avatar
He made this post also in the all motor thread (which he should of done so to begin with) and ALLMOTOR says it best
Originally Posted by ALL M0T0R
are you stupid?
12.7 isn't high?
Considering 12.5 is pushing the limits of pump gas, unless your tuned, your really in another world..
I run 12.8CR on mine, but my car, is tuned, very well, at full and partial throttle..
one lean spot, could melt a piston specially CTR's which are garbage in the first place.
Why would you rebuild?? With ctrs.. that piston is entirely too heavy, and no tot mention it distorts the flame front and it doesn't allow for proper combustion..
i wish people would read, ctr pistons aren't good.
Old Nov 6, 2009 | 07:25 AM
SpEeDyX's Avatar
Also hear is a picture i found that shows the difference in a b16 and gsr head that shows what makes it bad for p2v clearance
B16 /GSR
Valve clearance is another concern but this is what you need to check for, especially if the block & or head has been machined.
Old Nov 6, 2009 | 07:29 PM
bmwe362006's Avatar
I did a compression test today. it was at about 180 miles. it was 175 185 175 175. ive had different explanations most saying that it will slowly gain compression as you drive it and a few others said the rings should of already seated and something is wrong. The rings were put on correctly. I'm hoping it will slowly get better.
Old Nov 6, 2009 | 08:04 PM
Spawne32's Avatar
your just completely ignoring everything everyone is saying arent you
Old Nov 6, 2009 | 08:16 PM
FRESHTEG's Avatar
tune
Old Nov 6, 2009 | 08:43 PM
GagnarTheUnruly's Avatar
Here and in his post in the all motor forum as well...
Old Nov 6, 2009 | 08:51 PM
wunfstgsr's Avatar
Loved
Community Favorite
It will never run properlly untill you tune the motor! and running it hard in vtec is ruining the motor! those pistons give a **** load of compression and makes piston to valve clearence real close! thats why jdm itr pistons work better! you need to get your ecu chipped to tune the motor period! what are the rest of your mods?
Old Nov 6, 2009 | 09:09 PM
josh-roy's Avatar
TUNE.
Old Nov 7, 2009 | 12:30 AM
Honda_ThuGZ's Avatar
Originally Posted by josh-roy
TUNE.
x1500
Old Nov 7, 2009 | 04:07 AM
Tegraracer90's Avatar
if your not gonna take ANYONES advise...dont come on here
a motor is not like a growing baby as to were it gets stronger as it gets older...after the break in...were you sit...is basically were u sit
Old Nov 7, 2009 | 11:34 AM
MilanoRedDashR's Avatar
lol moron
Old Nov 7, 2009 | 02:11 PM
racebum's Avatar
if you don't tune this soon it won't be alive long enough to complain about
timing and a/f NEED to be adjusted. there is a good chance with this much compression the stock map will have too much timing and god knows where the AF is. burned valves and melted pistons happen when you do crap like this.
Old Nov 7, 2009 | 02:20 PM
bmwe362006's Avatar
I am going to get it tuned very soon. I am aware it needs to be tuned. My question was why is the compression so low. Tuning will not affect the compression. Anyways i checked the compression today at about 350 miles and it came out 185 200 195 210.
maybe some of you guys are wrong......
Old Nov 7, 2009 | 02:31 PM
SleeperGSR's Avatar
Great way to get help...good luck!
Old Nov 7, 2009 | 02:42 PM
teg_racer's Avatar
tune it. your gonna lean it out and your gonna burn it up
