ls vtec quik questionns...
Old Nov 5, 2009 | 06:37 PM
98ekgsr617's Avatar
Default ls vtec quik questionns...
I am getting ready to build a all motor lsvtec over the winter and i have a few quik questions about it..... what are the diffences between a b18a block and a b18b block and which would be better to use???.... also what wiring harness will i have to use if i put the motor in a 92-95 civic hatch?.. any info is helpful thanks
Old Nov 5, 2009 | 08:40 PM
dunkXdrift831's Avatar
Default Re: ls vtec quik questionns...
as for the difference in the blocks, im not sure. as for the wiring harness...its depends....you goin for obd1 or obd2?
Old Nov 7, 2009 | 04:38 PM
cruizinmax's Avatar
The b18a blocks have a oil separator on the back of the block like the vtec blocks that makes it easier to run the pcv system. The b18b blocks it is all built into the head so you will have to fab something up when putting the vtec head on there.
KRWTEK1
Jun 19, 2006 09:04 AM
raphael
May 9, 2006 05:53 PM
anewfoundkevin
May 3, 2004 10:44 AM
LBR92DA-T
Nov 15, 2003 07:13 AM
95redcivicex
Sep 16, 2002 08:45 PM
