issue with clear cost peeling off?
Old Nov 5, 2009 | 02:32 PM
ALL IMPORT's Avatar
Default issue with clear cost peeling off?
well i painted my engine bay about 2-3 years ago & when i was adding cage 2 my car recently i used my air gun toblow some stuff around my welds. about 125psi comming out of a 1/4 inch hole. & on top of my fender wells all the clear coat was jsut peeling off in sheets. wondering if i did something wrong when i painted it or just the high air pressure getting under it? never came off before.
when i painted the car i put white house of colors base coat. let it dry up for about 20 minutes then added my clear. ( one mistake i did make was i put the blue pearl powder in the clear not the base coat, & put alot ) probably put to much cause the color came out a little on the tan side. so maybe the powder messed it up?
what u guys think. wondering if i need to finish taking ALL the clear off or jsut sade whats left & go over it. tried air on other spots & nothing happens.
also whats the best way to knock that coating down in the fender wells, wire wheel ? or can u just smooth it up some & put a few nice wet coats of primer right over the crap?
also notice the lines along the joint sealer crap where it stoped peeling off
Old Nov 5, 2009 | 04:33 PM
christmastree's Avatar
Default Re: issue with clear cost peeling off?
How did you prep and clean it? The Pearl should not have made any difference. Plus your base peeled too. It appears to be prep or cleaning problems
Old Nov 5, 2009 | 04:41 PM
ALL IMPORT's Avatar
no the base didnt peal. the white is the base. the primer u see is new from when i added the extra cage section. cleaned it the same way i do everything wax/grease remover. then i sprayed the white base let it sit for about 20 min then sprayed the clear on with the pearl powder in it.
did this in my driveway but that shouldent really matter i wold think (no thier wasnt dust flying everywhere) exp to cause this.
also i always cleaned my car with simple green but cant believe that would cause it to flake off. it would of eaten through if anything
Old Nov 5, 2009 | 05:47 PM
Oh I thought it looked like the white peeled off on the corner of the shock tower. Did you mix the clear to the correct ratio?
Old Nov 5, 2009 | 05:48 PM
slow_srt's Avatar
If that white is your basecoat then why is it so shiny? Thats the problem.
Old Nov 5, 2009 | 06:02 PM
I think the more beige white is the base maybe?
Old Nov 5, 2009 | 06:31 PM
slow_srt's Avatar
He said he put so much pearl in the clear that it turned it beige. Said he sprayed the base and then cleared it 20 minutes later. I can't figure out why the base is so shiny. Who knows. If he didn't say otherwise it just looks like it was painted over a unscuffed surface.
Old Nov 5, 2009 | 07:46 PM
bar'dh22's Avatar
maybe shitty clear
Old Nov 6, 2009 | 06:33 AM
ALL IMPORT's Avatar
Can't remember the name of the clear I'll check when I get home. Don't know why the base is so shinny either. Also your not supposed to sand the base before clear if your putting it on right after right? Does it need to tottaly cure first or just a 20 min or so? Also everything was mixed correctly in the paint cups as per ratio. seems to be the only area I'll try the radiator support when I get home see if I can get that to flake off. that area was always being worked over & should of showed a flaw first for shure
Old Nov 6, 2009 | 06:39 AM
slow_srt's Avatar
Nope you are correct. You do not sand the base before clear. The base just needs to flash off before clear. Time depends on the temperature out, and the temp of the reducer you are using. But 20 minutes was probably fine.
Old Nov 6, 2009 | 04:27 PM
ALL IMPORT's Avatar
Oh well I'll make it work
Old Nov 7, 2009 | 05:37 PM
Hawkze_2.3's Avatar
Looks like you put clear over a single-stage white base....that's probably why it is so shiny. Basecoats flash to a dull finish ideal for topcoats.
Old Nov 7, 2009 | 09:07 PM
lil_cook97's Avatar
you just answer your own question. CLEANING WITH SIMPLE GREEN! I don't know if this stuff is a volitale as Purple Power or Super Clean but these two can take and dull off paint. Also if you didn't wipe it right off when you were cleaning it could've soaked into your panels and even and wax and grease remover couldn't take care of all of that. The best thing to do is water it down and clean it with soap and redo it all over again.
Old Nov 11, 2009 | 12:15 PM
ALL IMPORT's Avatar
never used the simple green until the car was painted. also used it on the outside of the the car & never had a problem. so dont really think that was it.
the outside has been primer only for 3 years ho9lding strong. but the simple green takes rubber off from the track very well
Old Nov 12, 2009 | 07:27 AM
slow_srt's Avatar
Ya, Simple green is not the problem.
Old Jul 8, 2010 | 01:56 PM
zepplinluvr's Avatar
Are you guys kidding? Your seriously trying to find out if the simple green affected the paint? I could tell you exactly what the problem is with your paint job.........
Old Jul 8, 2010 | 05:39 PM
D7_62's Avatar
to answer the second half of your question, if you want to repaint it, then sand it all down to 400, making sure there is NO shine(use a scotchbrite for the hard to get places) -clean off with cleaner first, wait for that to dry, then use wax and grease remover, paint, let it dry, 20-30minutes is fine, then clear. maybe its the clear you're using? try going a step up. Also, this is an engine bay, cheap clear under extreme heat may expand and contract and peel. Don't know what caused this. Everything you did sounds right. Even the simple green, ive used purple power, and its practically the same.
Old Jul 10, 2010 | 07:22 PM
crxcel's Avatar
my guess is you put the basecoat on too wet, trapped solvents and it didnt flash long enough. Solid colors are quite often shiny with just base. also if you did not use the same brand of basecoat clear coat that could be the problem as well
HamiltonRex
Paint and Body
13
Oct 8, 2009 01:41 PM
jman999
May 26, 2009 10:47 PM
Dead CIVIC
Paint and Body
Jul 3, 2008 04:54 PM
kraaaaap
Paint and Body
Dec 19, 2007 10:22 PM
GatchamanGSR95
Mar 27, 2002 11:52 AM
