B16A idling issue and RSX type S seats!
Old Nov 5, 2009 | 11:39 AM
eglover20's Avatar
Default B16A idling issue and RSX type S seats!
Hi All,
I searched for this and I found a LOT on the same issue, but I've followed all the given advice in those threads and i still have this issue. So here it is.
My eg coupe with a B16A swap into it, idles at 3500 rpm when its cold and 1900 rpm when its warm. First thing I check for is vacuum leaks but I find nothing. I pressed my hand against the throttle body and the rpm drops by about 300 down to 1600 rpm and that's it. I cleaned the IVAC and then replaced it, I replaced the TP sensor because my buddy broke it when he took it out. I replaced the hoses and made sure they were clamped properly. I ran the pcv and it did nothing. I don't know what to do next, I think I might go out and buy a Skunk2 IM and TB...
ALSO! I have two 2002 RSX type S seats, you guys think they would go well with my eg coupe? I'll need to get black seat covers to go with my black interior but other then that they're awesome! Any feed back on putting something like that in?
Old Nov 5, 2009 | 11:49 AM
Former User's Avatar
Default Re: B16A idling issue and RSX type S seats!
Your hand-covering-TB test indicates that you have a major intake air or vacuum leak.
Old Nov 5, 2009 | 11:51 AM
shoklid's Avatar
so the car should shut off if u cover the tb then right?
Old Nov 5, 2009 | 11:58 AM
Deetz's Avatar
Crazy Honda Guy
If i were you, i'd sell off the older rsx seats. The 02-04 models are not as good, they have cheap seat covers on them, wear badly, and are uncomfortable on any kind of longer trip.
The 05-06 seats are wayyy better in every aspect, i upgraded myself to the newer style
Old Nov 5, 2009 | 11:59 AM
eglover20's Avatar
Thats what I thought. My car JUST started throwing a CEL when I was driving, Code 14 Idle air control valve or bad ECM...
Old Nov 5, 2009 | 12:04 PM
yes
...I pressed my hand against the throttle body and the rpm drops by about 300 down to 1600 rpm and that's it.
Old Nov 5, 2009 | 12:05 PM
You have a major air leak.
Old Nov 5, 2009 | 12:06 PM
eglover20's Avatar
Those are the seats that I have, in that picture. I pulled them from a 2002 rsx...
Old Nov 5, 2009 | 12:19 PM
Deetz's Avatar
Crazy Honda Guy
Dude, the 2002 does not have those seats unless they were swapped, they didn't exist then. These are the crappy seats found in the 02-04 models
Old Nov 5, 2009 | 12:27 PM
eglover20's Avatar
Dude, they 2002 does not have those seats unless they were swapped, they didn't exist then. These are the crappy seats found in the 02-04 models
Ah, the seats in both those pictures look fairly similar...I'm sure mine are the cheaper ones.
austinkli
Aug 5, 2008 02:12 PM
preludedriva
Mar 26, 2007 10:13 PM
blackcivic44
Feb 12, 2005 09:20 AM
egjoe
15
Aug 28, 2003 07:52 AM
