After Ignition Coil Car Wont Start
Sup everyone,
I have a 95 LS and after having my car sit for about 2 months from breaking down, I replaced my Ignition Coil because the car didn't have a spark and along with that I replaced the rotor and distributor cap. But before the install, the car would at least crank and not start but now when I try to start it, I get no response at all like a dead battery.
What could be the problem now?
Any help is appreciated.
Are you sure your battery didn't go dead after the two month period of not driving it? I'd look into the grounds and the starter trigger wire as well. Once had the same problem and it was the ground from the stater being disconnected.
Well, I just replaced the battery with a fresh one, and I still get no response. Would there be anything else wrong other than that starter trigger wire? Any fuses maybe?
check all the fuses and by that I dont mean pull one by one, use a volt meter (google it if you dont know what I'm taking about), if all the fuses are good check your ground cables theres two of them one connected to the valve cover and another one to the top of the tranny (use and ohmeter to check the ground cables) if resistance is higher than .8 replace the cables, if the cables are good use a volt meter and check if the starter is getting a signal from the ignition switch, also make sure that the positive cable for the starter is good (again use a volt meter) good luck.
potential problem spots:
battery, engine ground, chassis ground, ignition switch, starter solenoid, starter wire (ignition switched +12, "trigger wire"), starter motor, starter motor power wire (+12 from starter solenoid), security anti-theft cutout components, clutch switch, starter cut relay (clutch switch controlled), automatic transmission gear position switch
=> no crank
did I miss anything fellas?
=> no crank
=> no crank
=> no crank
Spark-fuel-compression is what makes an engine start...
Battery:
check voltage levels: requires reconditioning/replacement of battery...common problem spot
Chassis ground:
check for continuity between chassis ground and negative battery terminal: requires cleaning of battery terminals, tightening on connection nodes, etc... common problem spot
Engine ground:
check for continuity between negative battery terminal and engine block: requires tightening of connection terminals, solidifying connections, etc... common problem spot
Clutch switch:
check for contact closure to ground while clutch is pressed: requires examination of wires, confirming proper switch position/actuation capabilities, etc... rare issue
Ignition switch:
check for voltage levels at each ignition switch position (with each directional swing): requires replacement... uncommon issue (?)
Starter cut relay (clutch switch controlled):
check for relay actuation with clutch pressed and key turned: requires replacement... uncommon issue (?)
Starter solenoid wire "trigger":
check for +12v on starter actuator wire (and be sure it is connected appropriately): requires reconditioning of terminal, re-examination of probable 'upstream' causes (such as clutch switch, chassis, etc), examination of continuity... commonly, its just loose.
Starter solenoid:
check for actuation of starter solenoid during crank key position (*click): requires reconditioning of solenoid, replacement, etc.
Starter motor power wire:
check for +12 volts at the motor power node: uhhh, I think most times this is internal between the solenoid and starter motor ?.
Security anti-theft cutout components:
check for appropriate actuation control of the anti-theft system relays: requires replacement, more following of anti-theft system wiring, etc.... unknown commonality
Automatic transmission gear position switch:
fill in the blank
Starter motor:
Check for humming while ignition in the start position: if the engine has an extreme load, or the motor is faulty (i.e. the commutators are worn badly and such) it may require replacement... uncommon issue
ECU:
Check for correct ecu control (yeah, I know, vague as hell): often, so socketing/chip jobs can be botched in such a way (i.e. an address pin of the ROM chip be pulled) where the ecu will cut all capabilities and such (?)... unlikely, but possible(?)
=> no crank
I tried to place them in an appropriate order of troubleshooting and may have missed a few. If anyone knows to add something I missed, please do so (I'm sure I can't remember all the details involved). I also tried to make it as generic as possible. Note: my judgment of commonality is solely based on my experience, others may differ greatly...
Good luck!
EDIT: For GSR, order is as follows: ignition switch, security starter cut relay (95-97), AT gear position switch OR starter cut relay, clutch control switch, security starter cut relay, starter solenoid (94,98), starter motor
Chassis ground:
Engine ground:
Clutch switch:
Ignition switch:
Starter solenoid:
fill in the blank
Starter motor:
ECU:
=> no crank
Good luck!
Actually, I have it back cranking now, after the new battery and I realized there was a cable disconnected from the starter.
But now when I try and start, the car cranks then theres a kinda thumping sound from the engine.
I think I might not have put the spark cables back in the right order on the dis. cap. Would that cause that sound?
Battery:
Chassis ground:
Engine ground:
Clutch switch:
Ignition switch:
Starter solenoid:
fill in the blank
Starter motor:
ECU:
=> no crank
Good luck!
Chassis ground:
Engine ground:
Clutch switch:
Ignition switch:
Starter solenoid:
fill in the blank
Starter motor:
ECU:
=> no crank
Good luck!
Well before I changed out my coil when I was trying to start it the car was still spraying gas in to the motor so had to check the pistons to make sure the were cool added some oil and fired right up had watch it for a few days
Check your Main Fuel pump Relay (make sure its making 3 clicks at #2, when battery light goes out, and when its on the on position )and Fuel Pump(turn the switch to # 2.,put your ear next to the fuel pump and if your here it spin or make a noise like pumping its Ok, don't replace it ), check if your injectors are in good working conditions . GL!
