Rear side window exterior trim.
Old Nov 5, 2009 | 06:00 AM
twentyhurtz's Avatar
Default Rear side window exterior trim.
hey guys, on my integra the two triangular windows (rear left and right sides) both hav the trim pulling away from the body, primarily in the rear where the trim is the most narrow.. it looks crappy now and i wanna replace them, have any of you ever done this or even know if this part is even available to order?
Old Nov 5, 2009 | 11:22 AM
717DC's Avatar
Default Re: Rear side window exterior trim.
im not sure but i was told from someone that that is actually connected to the glass? Ive been wondering the same thing too. In for results
Old Nov 5, 2009 | 11:28 AM
Spawne32's Avatar
its encapsulated glass, if you want it removed you have to call a glass company to come and cut them out with a special tool, they are about 130 dollars each new, i know what your talking about i just had mine removed because the seals are like that. I have them sitting in my garage and im gona try working them with the heat gun to get them back into position before i bother replacing them. In order to put them back in your gona need some 3m fast cure auto glass urethane adhesive.
Old Nov 5, 2009 | 12:21 PM
hmm... yea its not that they leak or anything, just disfigured and ugly because they flare out.. didn't think about adhering them back.. good idea..
Old Nov 5, 2009 | 12:34 PM
Spawne32's Avatar
if they are anything like mine, it wont hold even with urethane adhesive, y our gona need to heat them up and get them soft again and trying to move it back into position
Old Nov 5, 2009 | 12:48 PM
hmm.. sounds like this is a common problem, i have only seen it on mine down here, but from seeing these post i see that its an issue... aren't the windows just held in by studs? i think on my eg hatch they had acorn nuts on the inside you could unbolt and just pop the glass out..
Old Nov 5, 2009 | 12:51 PM
Spawne32's Avatar
nope, they are held in with urethane adhesive, ill have to snap some pics of my car with them out, you can see where they glue
Old Nov 5, 2009 | 01:14 PM
cool, thanks!
cedrichawkda6
Jan 16, 2011 12:12 PM
ITR #1202
Honda S2000
18
May 26, 2010 04:09 PM
Da1Gsr
Apr 8, 2006 04:24 PM
quikrpm'z
Nov 14, 2002 08:57 PM
quikrpm'z
Apr 25, 2002 10:35 PM
