b18c1 swap woes
Old Nov 5, 2009 | 01:53 AM
kyleb18t's Avatar
Default b18c1 swap woes
cel is on and throwing code 4.three distributors (distributorking) and im thinking its not the dizzy like hasport is saying is the problem. any help would be great because ive seen everything from clips not mating right in plug to mispinned wires in harness.so i need to know which wires on the plug at the ecu to check and which wires at the dizzy to check also.
Old Nov 5, 2009 | 06:23 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: b18c1 swap woes
Subscribing to this one. Will be throwing one in the sedan very soon. Someone help this guy out
Old Nov 5, 2009 | 08:17 AM
jlicrx's Avatar
first off, check your distributor wiring to see that it is correct - a lot of people (including some making OBD0 to OBD1 distributor jumpers) don't realize that some of the OBD1 distributor sensor wire colors are not the same as OBD0 distributor sensor wire colors
the TDC (top dead center, code 8) wire colors are the same on both OBD0 and OBD1:
orange with blue stripe (OBD1 ECU pin B13)
white with blue stripe (OBD1 ECU pin B14)
the CKP (crank sensor, code 4) wire colors are different on OBD0 and OBD1:
OBD0 = orange - OBD1 = blue with green stripe (OBD1 ECU pin B15)
OBD0 = white -- OBD1 = blue with yellow stripe (OBD1 ECU pin B16)
the CYP (cylinder position sensor, code 9) wire colors are different on OBD0 and OBD1:
OBD0 = blue with green stripe - OBD1 = orange (OBD1 ECU pin B11)
OBD0 = blue with yellow stripe - OBD1 = white (OBD1 ECU pin B12)
igniter wire:
OBD0 = white - OBD1 = yellow with green stripe
some aftermarket distributors have some of the sensor wires switched inside the distributor and end up at the wrong ECU pins - this is usually the orange and white wires for the CYP sensor which should give you a code 9, however, if the distributor wiring is not correct and instead has all of the wire colors matching, it would throw a code 4 - you may have to switch wire locations in the distributor connector to get them to run to the correct ECU pin
try switching the orange and white wires in the distributor connector
Old Nov 5, 2009 | 08:20 AM
BlackAlbumKoupe's Avatar
bumpppppp
Old Nov 5, 2009 | 09:54 AM
kyleb18t's Avatar
jlicrx thank you for the info.b15 and b16 here i come,lets keep our fingers crossed
Old Nov 5, 2009 | 08:51 PM
kyleb18t's Avatar
tried it,car wouldnt even start.hasport says to switch b10 b12
and i hope they dont want my death at this point lol
so we'll see if that helps,let you all know soon
Old Nov 7, 2009 | 09:26 PM
kyleb18t's Avatar
b10 and b12 again epic fail.
Old Nov 13, 2009 | 10:25 PM
kyleb18t's Avatar
well i pinned the problem out.two wires misplaced by hasport,moved the wires at the ecu and car runs, no cel ,nothing on hondata. yay
Old Nov 14, 2009 | 08:35 AM
213374U's Avatar
0x5359-0055
Community Builder
Which 2 were misplaced? Congrats on getting it fixed though
b16adx
Dec 21, 2005 12:46 PM
chadmasterc
14
Nov 17, 2004 10:33 AM
Ruby Civic
Mar 11, 2004 09:08 PM
untitled
Aug 5, 2003 05:44 PM
Audipwr1
May 10, 2003 05:17 PM
