Rotor help...
Just wonderng, what is the oem rotor size on the fronts and rears (5th gen)? Is there a drum brake (for the hand brake) in the rears as well? I was wondreing if you could put 'old' fronts in the rear if you upgrade the fronts...
The Front and Rear rotor sizes on the 5th gen are different... i recently bought crossed drilled and slotted rotors for my 5th gen, one pair is bigger than the other.. (not sure but i dont think it would work to use the front in the rear..)
I intend on using the complete front assembly, ie the caliper and the rotor from the front and place them in the back...if its possible, which is my question, along with the demensions of the rotor I think its like 11.1 in/282 mm I think...but am not sure, is that the right demensions?
Dekorum
Sep 14, 2018 08:48 AM
